Spymyto is hot!
- Buddafucco
Re: Spymyto is hot!
•• Beau
FaceplantIntoRock
Re: Spymyto is hot!
Just got mine.
Here's a quick shot of the internals:
I really like the way the inside of the Spydiehole is "crowned.":
Re: Spymyto is hot!
I just clicked your link for KnivesPlus and they had them in stock. I went ahead and ordered one. They're still showing in stockSSD_777 wrote: ↑Mon May 06, 2024 1:26 pmhttps://www.knivesplus.com/spyderco-spy ... anium.html
Edit: Out of stock
I had decided I didn't want one of these but you enablers caught me at a weak moment. Now there's one on the way. I figure, if nothing else, it'll be a nice one for my collection
EDIT: Now it says out of stock. We'll see if I actually get one
Re: Spymyto is hot!
Sharp Guy,Sharp Guy wrote: ↑Mon May 06, 2024 2:50 pmI just clicked your link for KnivesPlus and they had them in stock. I went ahead and ordered one. They're still showing in stockSSD_777 wrote: ↑Mon May 06, 2024 1:26 pmhttps://www.knivesplus.com/spyderco-spy ... anium.html
Edit: Out of stock
Did you receive confirmation from Knivesplus that the transaction went through?
If “yes” that means you got the knife.
Anyway it looks like the Spymyto is selling very fast.
FloridaMan
Re: Spymyto is hot!
Ha Bax. I’m on a bunch of lists to be notified of the release and seems they have not been sending the notification when they go on sale. I went ahead and got one from Robco knives on eBay for 247$. He has them posted now for MSRP as I’m sure they were flying off the shelf.
If I’m notified about a release on a site I will likely buy one then just resell for what I pay to help someone out looking or wasn’t lucky enough to get one.
ilikesharpstuff
Re: Spymyto is hot!
Available now at American Edge
ForgeThought
Re: Spymyto is hot!
Re: Spymyto is hot!
Hahahaha, you aren’t kidding! I’m stalking this thread! Check every half hour through the day.
Do not wait. The time will never be 'just right'. Start where you stand, and work whatever tools you may have at your command and better tools will be found as you go along. -Napoleon Hill
Re: Spymyto is hot!
List price but > has it https://www.countryknives.com/shop-by-d ... -titanium/
Re: Spymyto is hot!
Re: Spymyto is hot!
Sold out
FloridaMan
Re: Spymyto is hot!
Got one! Thanks!
Re: Spymyto is hot!
Anyone catch in the pamphlet that it says it includes a carbide glass breaker? guess they decided not to add this. wonder if the one from the Myto and its clip will fit the spyderco one, it looks much better than the standard metal clip.
Re: Spymyto is hot!
I would expect the clips to be interchangeable. However, I'm not 100% sure. Contact Lionsteel they might know.
Re: Spymyto is hot!
Re: Spymyto is hot!
I think there's a little misunderstanding here. The glass breaker mentioned in the PIG is in the "Design Inspiration" section, and it refers to the Myto, which inspired the SpyMyto. I hope this helps clarify.
Kristi
Spyderwebs
Re: Spymyto is hot!
Spymyto mixed in with the current SotC.
With only 12 hours on it, I really really like this knife. The flipper is kinda worthless - I tried it but prefer the spydie flick over the flipper. Cool feature, but removed. The relief around the flipper is kinda sharp, and does not feel nice if you mash your finger into it. For a successful flick I found it better to flip straight down, parallel with the handle, and no force into the handle.
Action is great. Smooth, no grit. Flicks and locks up very nicely. Lock has no stick. Engagement is mid-way so perfect locking all around. Buttery smooth with a little silicone lube, even before a proper break in.
The rounded spine and hole are great. I could get behind this on more models. Or I might try it myself on a rubber-silicone carbide deburring wheel on my Centrofante 3 or maybe Endela.
I like the clip more than I thought I would. I have deep carry on everything, and this one scratches that itch nicely.
The Micarta is nice - it feels slightly more 'filled' than the CruCarta did initially. Out of the box its almost gray-green. Not very 'OD green', but I like it. I see with a little wetting (from water) it darkens and becomes more greenish. It will age nicely with some hand oils.
The lines on this knife are really great. The rounded spine blends nicely with the pivot side contours. Very compact compared to a lot of Spyders with taller, triangular blades. Reminds me of a shorter Native Chief almost.
The edge came pull-cut sharp but not the sharpest one out of the box I have seen. Bevel is has minor centering mismatch, like 60/40, but not bad.
The only things Im not a huge fan of - Frame locks are less fidget-y than Comp or Back lock. The frame lock is growing on me, but in terms of a fidget thingy, frame locks are inherently less so. Not a big deal as the action, lock, and unlock is very nice, and I needed to try a frame lock. 2nd, the 4mm blade stock is a wedge. 4mm is overly thick for this type of knife. 3mm would have been ideal IMO.
The soft case was a very nice feature. Much better than the standard box. Fit an finish of everything is excellent.
If you are on the fence, your FOMO should be growing bigly.
