Show your mods!
vadel
#1101
Post by vadel »
Military BG-42
Gold plated screws, modified pivot, new backspacers instead of an old black insert, screws holes for clip modified for 2-56 screws
My :spyder:s: C85G2 (EDC), C63GPS, C63GPS2, C63GP3, C65CFP, C65BKP, C65TIP, C143GP, C90PBLE, C90CFPE, C10PGRE, C10PGRE FFG, C10SGRE, C11PGRE, C10JBB, C11JBBP, C11JBOP, C113CFPD, C28PGRE2, C149GP, C135GP, C126GPFG, C36GPBNXHP, C36CFM390P, C81GGY20CP2, C46GGY, C79OR, C142GP, C122GP, C136G, C148G, C28T, LSS3T, C150GP, C95G2
BOOMER52
Post by BOOMER52 »
After designing and building a CNC router I thought to use it to machine custom scales. Here's a Manix 2 with a small Anso pattern in tan, olive drab, & black urban camo G10.
BOOMER52
BOOMER52
Post by BOOMER52 »
After designing and building my CNC router I thought I'd do some scale work with G10 and such. This is a small Anso pattern in tan, olive drab & black urban camo on my Manix 2.
BOOMER52
May as well pic whore these out here too :D
Holland
Post by Holland »
Nice dye job evil! that looks amazing! may even have to copy you if i ever manage to pickup that knife :D
Holland wrote:Nice dye job evil! that looks amazing! may even have to copy you if i ever manage to pickup that knife :D
Imitation is the sincerest form of flattery :D
gooeytek
#1107
Post by gooeytek »
Sterilized, blasted, and etched the blade to remove scratches, finished the flats in satin, removed the sharp edges from the hump and rounded the spine.
cosmo7809
#1108
Post by cosmo7809 »
Evil D wrote:Yet another knife I would own if it had any kind of lock.
You have a index finger dont you?
Come Join Us Click Here
Pockets
#1109
Post by Pockets »
I think the issue is that he wants to keep it :D
Some of us are just paranoid...
Delica PE, Dragonfly Salt SE, Stretch SE, Manbug SE, Mule 16, Sage 1, black/satin PM2, Native 5
xceptnl
Post by xceptnl »
vadel wrote:Military BG-42
This is an outstanding mod that really makes that rare model a one of a kind!
*Landon*
cosmo7809 wrote:You have a index finger dont you?
Yes but it isn't always positioned under the choil to keep a blade from closing ;)
I live in a pretty nice neighborhood, but I still lock my doors. It just feels safer regardless of whether or not it's needed.
superclif
#1112
Post by superclif »
How did you remove the blade and hardware? Or does the dye not affect it?
Donut
#1113
Post by Donut »
IMO, that's the color "Tan" should have been. Nice work, David.
-Brian
A distinguished lurker.
Jazz
#1114
Post by Jazz »
vadel wrote:ParaMilitary2 CTS-20CP. It was ;)
I missed this one. That looks pretty cool, vadel.
- best wishes, Jazz.
Chipped Karambit
#1115
Post by Chipped Karambit »
These are amazing
RoBoTech
#1116
Post by RoBoTech »
Moroland wrote:Where did you get that thumbstud? I'd love to do that to my Pingo :)
I am modding a Pngo right now.
I have found that the "hole" is 3/16" (.185), so about any on this page
http://www.knifekits.com/vcom/index.php?cPath=60_94_95
that has the .185 step will work, with a small mod.
I use the dual thumbstud.
http://www.knifekits.com/vcom/product_i ... ts_id=1846
It comes with a open ended screw to put it on. The step will fit snug in the hole, but if the step is too LONG, you may have to cut some off. About 20 seconds on a disc sander, about two minutes with a flat file.
The polish the whole stud up nice.
The blade on the pingo is .110" wide. that means the step LENGTH has to be less than .055 on each side to fit snug when tightened up. I found that on my Pingo, .003 filed down on each side is enough to fit it tightly.
I will use blue Loc-Tite on mine, but if you want this to never come off without heat, use red Loc-tite on the threads. Then it will at least come off, but probably won't unless you really mean it.
Oh, and tho the page says allen wrench, there's none needed.
I am cutting scales for this today, but had to order a 1/16" mill cut burr for my drill press to mill in the wire clip slots. So it will be a week or so before I show the results, here.
Just my input, maybe some can give more.
SpyderScout
#1117
Post by SpyderScout »
RoBoTech wrote:I am modding a Pngo right now.
More input in regards to the Pingo, you say?
:D Certainly - here is mine:
Nanocyl, honeycomb, anodized titanium, Zircon sandwashed blade.
[SIGPIC][/SIGPIC]
RoBoTech
#1118
Post by RoBoTech »
SpyderScout wrote:
Nanocyl, honeycomb,
nice!
Did you have problems with the Nanocel material?
I have thought of using some of the red for another project.
And the clip cut out looks interesting.
SpyderScout
#1119
RoBoTech wrote:nice!
Thanks.
With proper precautions when handling/pouring no problems per se.
After vacuum treatment (and prior to cutting the outline for the scales), there were slight spots in the Nanocyl/honeycomb block, where the Nanocyl had not penetrated properly.
But that was just in the bits of the block, which were discarded anyway.
We are currently debating whether or not to skip the vaccum step altogether.
Work thread (and machine used for drilling the clip cut out) here:
http://www.spyderco.com/forums/showthre ... ight=pingo
[SIGPIC][/SIGPIC]
RoBoTech
#1120
Post by RoBoTech »
I did read that, and realized you guys made your own material. Very nice.
It isn't what I thought it was.
Here is the material I THOUGHT you used.
http://www.knifekits.com/vcom/index.php?cPath=40_466
C-Tek.
The reason I asked about the Nancyl stuff was because some people have reported some brittleness in the C-Tek when working it down.
But, it looks good when finished properly.
