Plain Edge VS Serrated Edge
Bill1170
Re: Plain Edge VS Serrated Edge
#101
Post by Bill1170 »
Sun Jan 04, 2026 3:03 am
JSumm wrote:
Sat Jan 03, 2026 7:03 pm
This is some very thin chip bag plastic.
To Vivi's point, it can leave some small plastic bits behind as it did on one of my chips. So that alone, I am 100% behind Vivi's choice of plain edge in the food service business. 😁
Let's go Bucs!!
Thanks for the contribution! Looks like a very smooth cut overall.
I don't eat chips but I've often used the small foil wrappers of cliff bars and similar snacks as test material for freshly sharpened knives.
highly polished edges that are merely scrape shaving sharp will slip on these sorts of materials a lot if they aren't cut by penetrating with the tip prior to slicing.
I like to slice right into these wrappers as I show in the video to make sure my edges are sharp. Perpendicular, as cutting at an angle away from where I'm holding also makes it easier.
Properly sharpened PE or SE should have no problems with doing it this way.
I like testing the edges on used knives I buy and trade into. I've come across more than one edge that was stropped and stropped and felt sharp enough with the thumb test but skated right over these materials slicing right into them like this.
That’s a tough test indeed, one where a toothy edge performs much better than a polished edge. I’m still learning after all these years.
40mm
#102
Post by 40mm »
Been going around the house and garage and cutting anything and everything I can find. From snack food packaging in the pantry, to cardboard, rope, and strapping the garage. Even found some tough plastic packaging. Going back and forth between the course plain edge and serrated edge, I’m not feeling a huge difference between perceived effort to get through the different materials. What I DO notice is that I much prefer the shorter blade length for cutting. The long edge almost feels like it’s getting in the way, or it I cut out more towards the tip, then I get less leverage. Might not not explaining that correctly but there it is. Could also be that I’m so used to the little dragonfly and hooking material into one of the larger serrations that the plain edge just feels more foreign to cut with. I think if I go back to carrying a plain edge knife I will make sure it’s a wharncliffe blade and definitely under 3 inches.
ChrisinHove
#103
Post by ChrisinHove »
Sat Jan 03, 2026 2:28 am
The SE Pacific Salt 2 I was carrying at the time would sometimes snag and rip pieces of plastic off and they'd get stuck on the food, which slowed me down while I inspected the meat for contaminates. So I went back to PE pocket knives & z cuts for line work and the issue was resolved.
What is the risk of the micro serrations of a coarse sharpened PE creating micro fragments of plastic wrap?
Larger pieces you can see and remove might be preferable, although I guess any food wrap is going to be fairly safe.
Scandi Grind
#104
Post by Scandi Grind »
I don't think plastic has a tendecy to break apart into micro fragments more just from being cut? Not sure though. That said I avoid using plastic where ever possible when food is involved since plastic isn't healthy in general. Things like plastic water bottles can leak micro plastics into the water, so plastic wrap may very well do the same with food contact. Still I would not think cutting it with a plain edge would increase the issue.
"They say don't speak ill of the dead, I say don't speak ill of the living, they don't care once they're dead."
-- Martha Crowley
#105
I think Vivi is talking about little pieces of plastic that get wripped off. The bag I cut to get to the chips to get the salsa in my mouth had a small piece of blue plastic on it. Big enough for me to pinch off the chip before it made it to my mouth loaded with salsa. I've had it happen a few times with serrated cuts. I would imagine if you are working in a restaurant that would not be an ideal presentation. Especially with chips and salsa. 😉
#106
Pardon the poor angles on these videos. Trying to find something to prop the phone on was not fun.
I had some double wall cardboard. The kind you see used for fruit/vegetables. Satin blade is serrated and DLC blade is Plain edge. The plain edge has been sharpened on benchstones. Lower than the factory angle. Not sure exactly what angle, but lower than factory. I just lay it down as flat as I have time for.
This one the plain edge got wedged. I was trying to cut perpendicular to make it as difficult as possible.
Now I switched to a 45 degree angle to the cardboard. Better this way with both blades as I switch back and forth, but felt a bit easier with the serrations. I did not do a good job showing which one I was cutting with. Blurple backspacer is serrated and the black backspacer is plain edge.
Sorry, these videos are terrible. 🤣
#107
cutting cardboard at an angle definitely makes a big difference.
Looks like the SE bodacious had an easier time getting through that.
If you had to estimate, what would you say the edge angle is on the PE?
I have been using www.streamable.com for the videos in this thread. they embed easily for everyones convenience. videos on free accounts only last 2 months though. been looking for a host without that restriction that also embeds nicely on the forum.
#108
JSumm wrote:
Sun Jan 04, 2026 7:55 pm
In my use my SE Spydies cut thick cardboard noticeably better than my PE ones do.
But again and again, this might or most likely WILL be due to the clearly steeper edge angle the former have.
But then and also again this is what probably a vast majority of knife users experience too, cause SE Spydies just come with that steeper angle right out of the box, and most people do or can not change the PE factory angles really dramatically...so out in the "real world", especially outside of this forum, SE will just have that advantage - and according to what Michael Janich and Sal said once more,still offer enough edge stability, even with such an acute angle also for inexperienced users.
How I personally feel about that is something I have to try, resp. very, not commonly seen acute PE angles and how they hold up!
#109
Sun Jan 04, 2026 11:13 pm
Really?
I posted only very few videos, but as (I think) you advised me back then I did use streamable, and definitely without an account and without paying anything.
Even vids back from 2020 can still be seen though... ? (for example viewtopic.php?p=1459252#p1459252)
#110
Not terrible, my friend! :clinking-mugs
But I agree, for me it is pretty hard too to make and post vids that are really meaningful.
I totally appreciate yours and especially what Vivi literally shows us here!
But I also think videos work better when wanting to show fundamentally IF and/or HOW something generally works.
Examples I personally did would be:
Are there several good ways to close a CBBL or backlock one handed and show those; Can a backlock generally be reverse-pinky-flicked. And so on
But vids as "prove" for finer details and differences, like it is the case here with PE "vs" SE do not work as well imo.
I still think they are cool and helpful, no doubt (!), but a lot of factors come into play, like how exactly a knife is sharpened, cutting technique, how and in what angle the procedure is filmed and so on.
#111
Sun Jan 04, 2026 11:25 pm
Yep, geometry plays a big role in many materials. Wood, apples, rigid plastic, and of course cardboard.
The majority of knife users never sharpen their knives.
The spirit of the thread is for us to make comparisons with our own knives of either edge type, not to base our discussion around average users.
We all agree most people don't thin out PE knives or even know they can sharpen SE knives - I don't think there is any benefit to repeating that.
What I am interested in is seeing people compare their different edge types and how their experience lines up with mine.
Another thing I'm interested in, is has anyone here reprofiled their PE knives to how thin their SE knives are, and found they did not hold up?
We have a number of users here who have reprofiled their knives to very thin angles if you check out the community sharpening journal. Myself, wandering about and u.w. come to mind.
I don't think any of us have experienced issues with our thin plain edged knives.
Sal has also reported running plain edged knives at 20 degrees inclusive and hasn't reported any issues. I believe it's Evil D that has a seriously thin looking Ayoob sprint too, I'd love for him to chime in on how it holds up.
I don't think there's any magic to the durability of serrated edges. I've seen damaged PE and SE cutting tools of all types.
I've seen serrated bread knives so chipped and rolled I could slide them across my skin using a decent amount of force and be in no danger of cutting myself.
There are also numerous chisel ground plain edged knives on the market, and plain edged knives with V grinds ground comparably thin to Spydercos serrated edges. The companies making them have been doing so for decades in most cases. In fact in some cases these designs are 100+ years old.
So plain edged knives can certainly handle thin edges too, and not just in the hands of people like me. Some examples:
- Floral knives are often chisel ground to 15-22 degrees inclusive. I'm pretty sure Victorinox has been producing these since over 50 years ago.
- Victorinox also made/makes the Trekker, One Handed Trekker, Soldier (new version) and Trailfinder. Most of these features CE blades with a chisel grind. I own a OHT and I have never had issues carving woods with the PE part ground to around 18 degree inclusive. I've mever heard of anyone having a problem with theirs.
- Emerson knives, marketed as hard use folders, come chisel ground as far as I know.
- Many Cold Steel knives come chisel ground, such as their push daggers and some of their Tantos, which they've been selling for 40 years. They've also produced the scandi ground Spike line since the 1990's which is ground quite thin with wood carving performance comparable to a Mora.
- Leatherman has used chisel grinds on many of their smaller plain edged knives like the Micra and Squirt.
- Many V ground japanese kitchen knives come with an apex ground at 12-20 degrees inclusive, thinner than Spydercos serrated pocket knives. They also produce a number of chisel ground patterns way more acute than serrated spydies.
- Many Kiwi knife models come with 8-12 dps plain edges.
- Traditional japanese utility knives and modern xacto knives both come with very thin chisel grinds, thinner than Spydercos SE knives.
I could list many more examples, but the point is there are countless production knives that have been sold for decades featuring chisel grinds or V grinds ground as thin or even thinner than Spydercos serrated knives. So it's far from unheard of.
In fact here are three examples from my own collection of knives that ship with geometry that's as thin or thinner than a typical serrated Spyderco:
Kom Kom chef knife, Mora Companion, Swiza locking floral knife.
The Kom Kom is 1mm stock with an estimated 9dps factory apex, V grind.
The Mora is their classic scandi grind ground at 11.5 dps according to their website. This one has been sharpened so there is no microbevel. It routinely carves knotty wood and even baton wood for kindling without edge failure.
The Swiza is their liner lock floral knife, ground at an estimated 21 degrees inclusive, chisel ground.
All three work great for on a variety of materials. The Kom Kom has just been used on food but as you'll see it cuts cardboard without issue. The Mora does bushcraft stuff which can be hard use at times. The Swiza I use for general utility like cardboard, rope, and breaking down plastics for recycling.
So there's really no shortage of plain edged knives ground as thin as serrated Spydercos that any consumer can purchase and use. So I see no reason for the discussion to be limited to how Spyderco specifically sets their edge angles between the two edge types. Especially on a forum full of people (mostly) with the knowledge and ability to modify their plain edge knives to whatever angle they please.
In fact there are few things I would recommend more to someone new to our hobby than learning how to modify geometry and grit finish on their knives to optimize their cutting ability. I can take a thick edged survival knife like an SRK ground at 23dps and make it outcut my Moras carving wood just by tweaking the edge angle, which I've done. Or removing the highly buffed factory edge and applying a coarse finish - that has so many benefits for a utility knife on many materials. It's no exaggeration to claim that on something like rope cutting the end user can see 4-8x greater edge retention compared to the factory edge by putting a 300 grit edge on their knife.
#112
Sun Jan 04, 2026 11:29 pm
Really?
Older videos of mine I uploaded without an account are still up like yours are.
However sometime ago they changed their policies with regards to new uploads.
2 day life for no account, 2 months for free accounts.
If I find a better host that embeds easily on the forum I'll mention it here.
#113
Did a little research and it seems Spyderco currently offers chisel ground plain edged blades themselves.
I don't own one but it appears it'd be in the 20 degree inclusive ballpark, using a steel with a reputation as being chippy (I've never had an issue with S30V personally).
Now, why do they make this particular knife ground so thin compared to other small, lighter use knives like the Ladybug, Grasshopper, etc?
No clue, but it shows even Spyderco is willing to mass produce plain edged knives with edge angles as thin as their serrated knives.
#114
Cutting open some coffee beans at work. This is that foil backed plastic. No snagging.
#115
Lower than 15DPS.
#116
Sun Jan 04, 2026 11:40 pm
;) I appreciate that. I'll keep trying.
#117
Michael Janich wrote:
Wed Dec 31, 2025 10:29 am
That statement was not based solely on theory; it was based on Spyderco's manufacturing practices and using a goniometer (which is shown in the photo immediately below that paragraph) to actually measure our factory edges. Most V-ground edges average around a 34-degree included angle. Most SpyderEdges average around a 17-degree included angle. Last time I checked, 17 was half of 34.
In relation to out of the box angles, remember what Mike said above.
I have often wondered that the edge results out of the box may be more related to the angle of the edge to the material being cut. For example, where I was feeling better results with SE on the double walled cardboard is when I would hold the blade perpendicular at roughly a 90 degree angle to make it as difficult as possible. Comparing PE to PE, at perpendicular but with the blade angled down (not 90 degrees), it can glide through a bit easier in my experience. I am talking about angle to the floor, not the angle to the cardboard trick we have all learned here on the forum. That angle is built into the edge of serrations. So out of the box, I wonder if that is what helps with SE on this type of thick material?
#118
Mon Jan 05, 2026 2:25 am
.....So I see no reason for the discussion to be limited to how Spyderco specifically sets their edge angles between the two edge types. Especially on a forum full of people (mostly) with the knowledge and ability to modify their plain edge knives to whatever angle they please.
Thanks, Vivi, for the detailed reply and the many good points and insights!
Short answer for now, but it is important for me to point out:
- I do find it exactly very interesting and very valuable that you take out of the equation the advantage SE has right out of the box but that has nothing to do with the teeth themselves - which is the steeper angle!
So I fully agree to NOT limit the discussion to "factory edges"!
I just want to point out for folks who perhaps just casually skim through text and/or vids that this is not what is to be expected with usual Spydercos right out of the box, but that in order to experience PE like you do people have to do their homework first.
Which I will do, and as said before: I´d actually like to come back to preferring PE, just cause this would give me more (Spyderco-)options!
Red Leader
#119
Post by Red Leader »
Has anyone taken a serrated edge and converted the chisel grind to a normal V-style grind? It would probably take that 15 deg chisel grind and split it to have around 8 deg per side.
One limitation I have seen with my serrated edges (chisel ground) is their propensity to pull to the side.
Can you still maintain the edge strength from serrations but have the benefit of straight cuts? Is there a history only seeing a chisel grind to serrations, or is it expediency?
#120
Red Leader wrote:
Mon Jan 05, 2026 9:10 am
How would you turn the around 15 degrees of the scalloped side to 8 degrees?
This would mean that you'd have to extend the scallops much higher up the blade yourself, right?
