Spyderco/Farid K2
Blerv
Re: Spyderco/Farid K2
#281
Post by Blerv »
Hey Jim,
I recall the re-ground 110v Manix2 was around 3,000 yards. Maybe I'm not in the ballpark though. Also, are you slicing with a particular part of the blade or is it a full-blade cut?
Regardless, that's an insane amount of cardboard. Kudos to the knife and more important: To your poor hand. :)
Ankerson
#282
Post by Ankerson »
Blerv wrote:Hey Jim,
One part of the blade, about 1/2 of the blade, you can tell when the photos go up what part that is... :)
Ankerson
#283
Post by Ankerson »
After 5500 Ft of cardboard...
And it would still slice Phone Book Paper after.... Not easy, but it would do it....
MacLaren
#284
Post by MacLaren »
I believe the S110V did 3800 ft around 1200 yards.
Ankerson
#285
Post by Ankerson »
I believe the S110V did 3800 cuts around 1200 yards.
Yep, S110V 3800 ft. :)
The K2 did 5500 ft for 1833 yards....
MacLaren
#286
Post by MacLaren »
Wow, the K2 had apprx 567 more yards....
Ankerson
#287
Post by Ankerson »
MacLaren wrote:Wow, the K2 had apprx 567 more yards....
I stopped at 3800 with the S110V blade, it would have cut a lot more..
This time with the K2 I cut until i ran out of cardboard, and I am out..... And it was 5500 ft.... It will still cut more....
WorkingEdge
#288
Post by WorkingEdge »
So Jim - how do you think it would do with a very fine edge?
I can't stop polishing my edges for some reason.
Ankerson
#289
Post by Ankerson »
WorkingEdge wrote:So Jim - how do you think it would do with a very fine edge?
Well, I have tested CPM 10V with a polished edge before... It likes coarser edges better....
Should do fine with a 1000 grit edge or so though.
Ignaz
#290
Post by Ignaz »
I would still say CPM S110V and CPM 10V perform quite similar.Yes the K2 cut around 45% more than the Manix but it also has got 1,47945 times more useable cutting edge.
Ankerson
#291
Post by Ankerson »
They are actually really close from my own testing using like blades in the same hardness range, within 25% anyway..... That's close.....
MacLaren
#292
Post by MacLaren »
That's a lot of work. Thank you Jim
Ankerson
#293
Post by Ankerson »
MacLaren wrote:That's a lot of work. Thank you Jim
YW... :)
5 Hours of cutting cardboard.... :eek:
WireEdge Roger
#294
Post by WireEdge Roger »
Wow, thanks for doing that! So how was 5 hours with that big, flat handle?
faridknives
#295
Post by faridknives »
Jim and I have been great friends for many years, I am glad he has done this test.
Take care Jim,
Farid
Laethageal
#296
Post by Laethageal »
I wonder what Phil, Cliff and Joe will say about the test they put the knife up to.
Ankerson
#297
Post by Ankerson »
faridknives wrote:Jim and I have been great friends for many years, I am glad he has done this test.
Take care Jim,
Farid
Yep. :)
Keep up the great work man. :)
Ankerson
#298
Post by Ankerson »
Laethageal wrote:I wonder what Phil, Cliff and Joe will say about the test they put the knife up to.
Looking forward to seeing what they come up with. :spyder:
The knife wore me out..... :eek:
xceptnl
#299
Post by xceptnl »
Your test brings to light the level of performance we are all facing with this knife.... despite the buying lockout I am facing, this may force me to reallocate funds from somewhere to land one of these in my stable. Thank you for your effort Jim.
*Landon*
Ankerson
#300
Post by Ankerson »
xceptnl wrote:Your test brings to light the level of performance we are all facing with this knife.... despite the buying lockout I am facing, this may force me to reallocate funds from somewhere to land one of these in my stable. Thank you for your effort Jim.
Thanks, will have to wait and see how the other 3 fair once they start testing. :)
