Brown s35v Para 2s C81GPBN2
How rare are these and can they be found anywhere?
Own: C81GPBN2 x 2
Wanted: FB30GP, FB37GGRP, C180GP, C10FPBN x 2, C11FPBN & FB35PBK and a C204MF most of all!
this was distributor exclusive. I believe that there were at least two batches. As for pricewise at this moment I would grab dark green instead. Steel is much more different that regular production S30V. If you care that much for brown scales, probably will be less expensive to get standard para and buy brown scales. Steel is about the same.
Sorry to kick this out from the grave but I am so excited!
I finally found one nib! and it's on it's way!
I have wanted one since they first came out but didn't jump!
This is also my first spyderco I may be sleepless till it arrives.
Own: C81GPBN2 x 2
- senorsquare
- Liquid Cobra
BHQ has 22 in stock at the moment. It was 23 but I just ordered one. $150 seems like a very fair price indeed. Thanks for the heads up.
@liquid_cobra
@liquid_cobra
- Spyder-fan
I got to see both available (green and brown) but waited too long it was too late for the green but I got the brown, I do prefer the brown color but would have preferred the steel from the green. But you can't have it all and actually this one will be my first s35vn but I hear its similar and maybe a little better than 154 but softer than s30v.
Keep'em sharp :spyder: 9 Enduras, 4 Manix, Manix XL DLC, 3 Delicas, 5 Ladybug, 2 Manbug, 4 Dragonfly, Pingo, Cat, 3 Salt1, Pacific salt, Tasman, 3 stretch, 2 Tenacious, Resiliance, Robyn2 G10, 2byrd hawkbill, 4Para2, 2Military, native5 frn, Bradley folder, SpyDK, Kiwi, MT19, salt saver, Street bowie, Roadie,Squeak, 5 UKPK, k05 SE, k04 SE & PE
I don't recall hearing that S35vn was softer than S30V. I thought they were supposed to be pretty similar in properties. You mean the HRC? I think that depends on heat treat. I could be wrong though. Either way, you and I are both looking forward to the brown para 2opusxpn wrote: this one will be my first s35vn but I hear its similar and maybe a little better than 154 but softer than s30v.
Well don't have experience with it but I will compare it to see what it does, either way VG10 does it for me anything above that is just the cherry on top. I like the brown color I am excited.jtoler_9 wrote:I don't recall hearing that S35vn was softer than S30V. I thought they were supposed to be pretty similar in properties. You mean the HRC? I think that depends on heat treat. I could be wrong though. Either way, you and I are both looking forward to the brown para 2
- Liquid Cobra
There was a thread on blade forums that divided up the various steels into classes. I can't recall the name of the guy who posted it so I can't find it. Anyone?
@liquid_cobra
@liquid_cobra
