Black Southard is Coming!
Yeah I know you could change the scales and if the release proceeds with brown and I actually like the Stretch enough that I feel that I must get one........then I'd absolutely have to change the scales. Otherwise I'd constantly feel like I was sticking a turd in my pocket and it would irritate me to no end if I didn't change the scales.RadioactiveSpyder wrote:It's pretty easy and very cheap to change the stock brown scale to black you know... :) . Plus all the available aftermarket scales available, it's one of the most dynamic mod models out there! Clip is easy enough to change too, courtesy of STR over on BF. Cheers, Radioactive
Hopefully they release two Sprints of the slabbed version before going to FRN releases. Maybe a CF Super Blue version? But I would hate to have to pay another $50-70 just to make an otherwise awesome knife presentable to myself and others.
- jabba359
I believe RadioactiveSpyder was referring to a $3 RIT dye job, not actually replacing the scales.ManixFan wrote:Yeah I know you could change the scales and if the release proceeds with brown and I actually like the Stretch enough that I feel that I must get one........then I'd absolutely have to change the scales. Otherwise I'd constantly feel like I was sticking a turd in my pocket and it would irritate me to no end if I didn't change the scales.
- RadioactiveSpyder
I also like the brown scales. I dyed mine black only because I dropped my Southard in the grocery store parking lot and dinged the end of the scale. After sanding it out, the color contrast with the lighter sanded area was too noticeable and I was too cheap to buy an aftermarket scale. Some of the ones I've seen are incredible, and pictures I've seen of the new black version are fantastic!!
Does anyone know if STR offers his Southard Ti clips in black off-hand?
Hmmm, the brown G10 gets lighter with sanding? There might be hope for the brown G10 Stretch then. I really would prefer something other than black G10 (unless it also has the black blade it is just too common place) but if the brown sands down enough that it becomes light enough to go to a blue or green......even if it is a darker blue or green then maybe the G10 version of the Stretch would be salvageable with a dye job.RadioactiveSpyder wrote:I also like the brown scales. I dyed mine black only because I dropped my Southard in the grocery store parking lot and dinged the end of the scale. After sanding it out, the color contrast with the lighter sanded area was too noticeable and I was too cheap to buy an aftermarket scale. Some of the ones I've seen are incredible, and pictures I've seen of the new black version are fantastic!!
How much lighter did it get and do you think that it would be possible to take it to a dark blue or green with Rit dye?
- demoncase
It's deposited by Physical Vapor Deposition, not by an electrolytic plating process.
http://en.wikipedia.org/wiki/Physical_vapor_deposition
For reference:
TiN, TiCN, TiALN are all deposited using one of the PVD variant processes- either sputtering or evaporative deposition.
DLC are generally deposited using Plasma Deposition, usually Cathodic Ray Deposition.
Source: 15 years in NADCAP approved Special Processes, 10 years in Aerospace Manufacturing (Quality) and Bsc (Hons) Materials Science
For reference:
- Spydersense
