Shaving with a Spyderco?
SpyderEdgeForever
Post by SpyderEdgeForever »
If you had to use it as a razor for your facial hair or other hair, what Spyderco knife would be best suited for shaving?
wmcilvain
Post by wmcilvain »
zdp delica i have trimmed the edges of my beard with it before.... work pretty well for a few hairs
Johnnie1801
Post by Johnnie1801 »
I'm guessing something like an FFG Endura would be good as it's kind of similar to a straight razor.
I have actually been thinking about buying a straight razor to shave with as the price of razor blades is going up all the time. Does anyone here use one? Would be pretty cool to have a Spyderco Razor.
Jon
PanChango
Post by PanChango »
I would say the Roc. I would want to dremel out handle to get a better purchase closer to the blade.
I really wouldnt want want to shave with a pocket knife when I have a perfectly good straight razor.
MacLaren
Post by MacLaren »
A FFG Yojimbo 2?
chuck_roxas45
Post by chuck_roxas45 »
[video=youtube;wccP1D9iw-8]https://youtu.be/wccP1D9iw-8[/video]
razorsharp
Post by razorsharp »
Any knife sharpened sharp enough.... My personal pick is the serrated matriarch
hawaiihunter
Post by hawaiihunter »
I would shave with a whale rescue personally.
Looking for: Grey Cts-20cp Paramilitary 2
Green Cts-204p Paramilitary 2
S110v Mule
Currently own: Tenacious, Green Cts-204P Paramiitary 2
hawaiihunter
Btw, chuck what is that, 15 dps per side?
S110v Mule
anagarika
Post by anagarika »
I've used Resilience before, easy to get that shaving smooth sharp, and been trying to make my GB and Endura SB as shaving knives. Works ok, but yet to match a small 52100 customer I have.
Needs to be smooth, so it's a challenge there.
chuck_roxas45 wrote:[video=youtube;wccP1D9iw-8]https://youtu.be/wccP1D9iw-8[/video]
Chuck,
Any tips for the GB smoothness, .25u diamond paste strop? .1?
3rdGenRigger
Post by 3rdGenRigger »
Thinnest stock (Chaparral I would think), though I'm a sissy and use an electric shaver. I have had fairly bad eczema my whole life and given the variations of my skin day to day, I can't imagine a knife being conducive to a good shave with my skin, but I'd try a Chaparral before any other Spydercos if I had to (I always had the best luck test shaving arm or leg hair in short amounts with it before I sold my Chaparral).
All Glory To The Hypno-Toad
---> Branden
chuck_roxas45
anagarika wrote:I've used Resilience before, easy to get that shaving smooth sharp, and been trying to make my GB and Endura SB as shaving knives. Works ok, but yet to match a small 52100 customer I have.
Chuck,
My finest paste is 1u. Finer would probably be better. :)
anagarika
Post by anagarika »
chuck_roxas45 wrote:My finest paste is 1u. Finer would probably be better. :)
Thanks. I'll try that. Some more knowledgeable folks say that high Vanadium carbide is not to be taken too fine ...
bornagainprimative
Post by bornagainprimative »
hawaiihunter wrote:I would shave with a whale rescue personally.
That made me almost spit it my water hahaha
Own: C81GPBN2 x 2
Wanted: FB30GP, FB37GGRP, C180GP, C10FPBN x 2, C11FPBN & FB35PBK and a C204MF most of all!
chuck_roxas45
hawaiihunter wrote:Btw, chuck what is that, 15 dps per side?
Around 14 dps. Micro'ed at around 18 dps.
For the win! :D
v8r
Post by v8r »
Se Civilian :)
Only Chuck Norris shaves with a Whale rescue blade.
V8R
Opinions are like belly buttons most people have one:p
Cujobob
Post by Cujobob »
Something with a low carbide steel that could take a very fine edge is what you'd need.
Scorpion
Post by Scorpion »
Toss-up between Rock salt and Warrior. But seriously I have shaved with my Manbug before. It worked better than the box cutter blades. Don't ask.
Sequimite
Post by Sequimite »
I bet the original Puuko would do a good job.
.357 mag
Post by .357 mag »
v8r wrote:Se Civilian :)
Chuck Norris uses just his finger..
