Every now and then I have seen old butcher's knives that are literally so used to cut meats that the blade has been resharpened so many times, it is worn down to literally a thin strip of steel. I know many nowadays would likely get rid of such and turn to a new blade at that point.
But has anyone here ever used a Spyderco knife or seen a Spyderco knife that has been used so much so, and resharpened so much so, that the main body of the blade steel is worn down to a mere fraction of what it was when new?
What is the most worn-down Spyderco you've used or seen?
- SpyderEdgeForever
- ChapmanPreferred
Many. I witnessed a Micarta Dyad Jr that the PE blade was sharpened so much on something electricly powered that the tip was proud of the handle. I have purchased badly damaged Spyderco's in the past and repaired them to a usable status. Some of my favorite knives to use are the ones I rescued from the scap heap.
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
Work EDC List
[SIGPIC][/SIGPIC]
