Favorite Locking Mechanism?
- Strong-Dog
Which one do you prefer for your folders? Or do you prefer slip-joints?
"For a second, I thought I was dead, but when I heard all the noise I knew they were cops. Only cops talk that way. If they had been wiseguys, I wouldn't have heard a thing. I would've been dead."
-Henry Hill
-Henry Hill
- Spydersense
The Compression Lock is my favorite just because I just feel it has the best overall balance of all the attributes I care about: Strong, unlikely to disengage accidentally yet very easy and ergonomic to release on purpose, keeps your fingers away from the path of the blade when closing. The only real downside to it that I can see is that it's right-hand biased (though can be made in a left-handed version).
2nd place for me would be the Bolt Action lock as implemented on the Sage 3. It has the smoothest operation of any lock mechanism I've ever used, by far.
I like linerlocks because they are easy for me to use and I've been using them for a long time so they are second nature. Good access to the liner is key to making these easy to use.
I like the BBL for several reasons but mostly because it has a much different affect on the feel of the blade during opening. With a liner lock, frame lock, probably a compression lock, if you don't open the blade in a deliberate motion the lock might not lock up as well. With the BBL you can open the blade very slowly and when you get nearly open the lock will take over and engage fully.
In reality though I require a frame lock, liner lock, BBL, compression lock or axis lock. Otherwise I don't give any consideration to the lock type when I consider buying a knife.
Imagine a Manix 2 with an axis/arc lock though. For some reason the CBBL ends up with a lot more spring tension than the competition. I operate my Manix 2's CBBL with thumb and finger, my SOG Visionary (an awesome knife, even though it's not Spyderco) with just the thumb.Spydersense wrote:As a Manix 2 fan, I prefer the ball bearing lock the most. :cool:
Frame locks for some reason are cool, even though they're just big liner locks. I think it's just a meatier bar to push on.
All God's critters have knives.
If you like the axis lock, you should definitely handle a Sage 3 to check out Spyderco's implementation of the bolt action lock. It is VERY similar in how smooth and fluid it feels. You can flick the blade open or closed effortlessly.zhyla wrote:Imagine a Manix 2 with an axis/arc lock though. For some reason the CBBL ends up with a lot more spring tension than the competition. I operate my Manix 2's CBBL with thumb and finger, my SOG Visionary (an awesome knife, even though it's not Spyderco) with just the thumb.
Listening to myself here, maybe I should change my vote to the bolt action lock! :D
Mid lock for me because I am most used to EDCing it and I like that it helps with blade retention in closed position... :D
uncaged BBL is my favorite for gadget factor-- it's just plain cool :cool:
compression lock is my least favorite...it's probably the toughest, but I just dont like its placement
What is truth? Pontius Pilate
- The Mastiff
Lockbacks for me. No question.
2nd is Comp. lock
3rd RIL
2nd is Comp. lock
3rd RIL
On my Spydercos, the compression lock. Such as the one in my PM2 and SuperHawk.
My next favorite one is the liner lock on the Military, but only due to the huge opening (meant to be used with gloves) since I can easily work it as a lefty (my Mili is a standard, right hand model).
Wanted: Superhawk - Found!
- Strong-Dog
I personally like the BBL. I also enjoy a good liner lock and a compression lock, and even a simple backlock. I don't really like framelocks though
-Henry Hill
-Henry Hill
Compression Lock > Integral Frame Lock > Back Lock
Hi Folks!
My All-Time Fav is the Compression Lock. :spyder: Followed really close by the Integral Frame Lock. :cool: And the Back Lock comes in third place. :) My least preferred lock systems would be those where some gunk or debris could get inside, like the Ball Bearing Lock or the Axis Lock.
Stay Sharp!
- All-R-Crazy
- SaintlyBrees
I hate to say it on a Spyderco forum, but the Axis lock is my favorite. Amongst the many excellent locks that SPyderco has in their lineup, the back lock is my favorite followed closely by the ball bearing lock and then the compression lock. Every lock made by Spyderco is solid and works as it should - in my experience. I'm quite happy with all the locks on my Spydies.
My Spydies:
6 Manix 2 [blk/blk S30V, blk/blk XL, blue Sprint, blue LW, S110V LW, S90V CF XL]; 2 Delicas [VG10, Super Blue]; 4 Dragonflies [Tatoo, VG10, ZDP-189/Nishijin, Super Blue]; 4 Natives [S30V, Brn CTS-XHP, G10 S35N, Forum S110V]; 2 Chaparrals [Stepped Ti, CF]; 3 PM2s [blk/blk, blk/red Putnam, GRN CTS-204P sprint]; 1 CF bolt-action Sage; 1 Air; 1 Super Blue Manbug; 1 blk H1/blk frn Pacific Salt; 2 Stretch [Super Blue, ZDP-189]; 2 Enduras [VG10, blue jigged bone Damascus]
I don't actually think this kind of question proves much. There's an awful lot more to a knife than the lock. Blade type/grind, blade steel, handle shape, size of the handles and the blade, ergonomics. The lock is just one piece of the puzzle. :spyder: And yes, I have Axis lock knives that I think are the bee's knees. :)SaintlyBrees wrote:I hate to say it on a Spyderco forum, but the Axis lock is my favorite. Amongst the many excellent locks that SPyderco has in their lineup, the back lock is my favorite followed closely by the ball bearing lock and then the compression lock. Every lock made by Spyderco is solid and works as it should - in my experience. I'm quite happy with all the locks on my Spydies.
- Strong-Dog
This question wasn't meant to prove anything, just find out which type of locking mechanism people prefer. I love the BBL, but my most used and carried knives are backlocks.JNewell wrote:I don't actually think this kind of question proves much. There's an awful lot more to a knife than the lock. Blade type/grind, blade steel, handle shape, size of the handles and the blade, ergonomics. The lock is just one piece of the puzzle. :spyder: And yes, I have Axis lock knives that I think are the bee's knees. :)
-Henry Hill
-Henry Hill
