How many locked in the tower or in the dungeon? Doesn't matter brother, as long as they're brought into the light every once in a while! Ha, Ha, Ha!The Deacon wrote:Since the only knives I have in XHP are "safe queens, all I can say with any certainty is that it doesn't look any more (or less) attractive than VG-10 or S30V.
Well in that case, I guess since I'm getting those uf sharpmaker stones, the xhp Millie will be a good one to play with.chuck_roxas45 wrote:I.would recommend xhp.for people who.like polished edges. For me xhp.is still.agressive with a polished edge. If you're into.coarse edges, I suggest s30v over xhp.
In my experience, XHP is great with a polished edge. It holds a fine edge almost as long as ZDP for me that for my uses, it's a stainless ZDP but "easier" to touch up. With coarse edges on both S30V and XHP, it's my experience that S30V seems to hold a working edge longer but if both are polished, the XHP will hold that fine edge longer than S30V.Surfingringo wrote:Well in that case, I guess since I'm getting those uf sharpmaker stones, the xhp Millie will be a good one to play with.![]()
In that case Spyderco should really polish that blade on the Slysz Bowie.chuck_roxas45 wrote:In my experience, XHP is great with a polished edge. It holds a fine edge almost as long as ZDP for me that for my uses, it's a stainless ZDP but "easier" to touch up. With coarse edges on both S30V and XHP, it's my experience that S30V seems to hold a working edge longer but if both are polished, the XHP will hold that fine edge longer than S30V.Surfingringo wrote:Well in that case, I guess since I'm getting those uf sharpmaker stones, the xhp Millie will be a good one to play with.![]()
Try doubling the number of strokes going from brown to fine to UF rods each time you change grit. For example, 10 strokes per side on the brown, 20 per side on the fine, and 40 per side on the UF with the lightest contact that you can manage. You might like the results.
Users browsing this forum: Google [Bot], ladybug93, LarryInLex, Majestic-12 [Bot], RamZar and 29 guests
