What is your opinion of CTS-XHP?
bchan
Postby bchan » Fri Jan 03, 2014 5:25 am
Hello all, I am thinking of to buy a knife to try out the CTS-XHP steel. For those who have experience working with this steel, how does it compare to say VG-10 or S30V? Thanks.
eric m.
Postby eric m. » Fri Jan 03, 2014 7:06 am
Buy the knife! :)
Postby The Deacon » Fri Jan 03, 2014 7:20 am
Since the only knives I have in XHP are "safe queens, all I can say with any certainty is that it doesn't look any more (or less) attractive than VG-10 or S30V.
eric m.
Postby eric m. » Fri Jan 03, 2014 7:38 am
The Deacon wrote:Since the only knives I have in XHP are "safe queens, all I can say with any certainty is that it doesn't look any more (or less) attractive than VG-10 or S30V.
How many locked in the tower or in the dungeon? Doesn't matter brother, as long as they're brought into the light every once in a while! Ha, Ha, Ha! :)
Postby Doc Dan » Fri Jan 03, 2014 8:00 am
I have a knife with this steel and so far I am very happy with this steel. I would love to have a Spyderco fixed blade hunting knife with this steel.
(Roy Rogers)
Holland
Postby Holland » Fri Jan 03, 2014 2:15 pm
Decent steel, I think it's overrated though. There have been quite a few tests where s30v out performed it
78lilred
Postby 78lilred » Fri Jan 03, 2014 2:33 pm
It does seem to get a lot of hype/rave reviews, personally in my experience it's more enjoyable than s30v. I've got a para2 and techno with it and the bevels polish nicely.
M390 Para2, CTS-XHP Para2, CTS-204P Para2, Gayle Bradley, Techno, Bob T Slipit, M390 Mule, Southard, Southfork, Air, Tuff, ZDP Caly 3.5.
hunterseeker5
Postby hunterseeker5 » Fri Jan 03, 2014 3:40 pm
Broadly its very comparable to S30v. Any performance differences you see between it and S30v are likely due more to differences in geometry, sharpening, and heat treat than differences between the two steels. That doesn't make it bad, we seem to all love S30v as well, it just means its a nice steel rather than the second coming. :)
Donut
Postby Donut » Fri Jan 03, 2014 3:46 pm
I've heard it compared to VG-10 on steroids, I think that is pretty accurate.
People say the Wear Resistance is in line with CPM-S30V. CPM-S30V is supposed to be chippy, CPM-S30V is designed to offer higher wear resistance when toughness isn't needed. CTS-XHP has more toughness than CPM-S30V, so it should offer you a more well rounded user steel than S30V depending on what you use it for.
I would love to see some beater tests done with these two steels to see how the difference in toughness affects us in actual use.
It does seem to sharpen similar to VG-10.
-Brian
A distinguished lurker.
Waiting on a Squeak, Pingo, and Cliptools with a Split Spring!
bpeezer
Postby bpeezer » Fri Jan 03, 2014 8:24 pm
Polishes easily like VG-10, holds its edge like S30V. What's not to like :)
gbelleh
Postby gbelleh » Fri Jan 03, 2014 8:43 pm
[video=youtube;28GLa9T2CtI]http://www.youtube.com/watch?v=28GLa9T2CtI[/video]
:D :spyder:
Surfingringo
Postby Surfingringo » Fri Jan 03, 2014 9:01 pm
bpeezer wrote:Polishes easily like VG-10, holds its edge like S30V. What's not to like :)
I have an xhp Millie on the way and I hope this is true. Something that would easily take an edge like vg10 but have better edge retention would be a dream!
chuck_roxas45
Postby chuck_roxas45 » Fri Jan 03, 2014 9:14 pm
I.would recommend xhp.for people who.like polished edges. For me xhp.is still.agressive with a polished edge. If you're into.coarse edges, I suggest s30v over xhp.
Surfingringo
Postby Surfingringo » Sat Jan 04, 2014 4:37 am
chuck_roxas45 wrote:I.would recommend xhp.for people who.like polished edges. For me xhp.is still.agressive with a polished edge. If you're into.coarse edges, I suggest s30v over xhp.
Well in that case, I guess since I'm getting those uf sharpmaker stones, the xhp Millie will be a good one to play with. :D
chuck_roxas45
Postby chuck_roxas45 » Sat Jan 04, 2014 5:08 am
Surfingringo wrote:Well in that case, I guess since I'm getting those uf sharpmaker stones, the xhp Millie will be a good one to play with. :D
In my experience, XHP is great with a polished edge. It holds a fine edge almost as long as ZDP for me that for my uses, it's a stainless ZDP but "easier" to touch up. With coarse edges on both S30V and XHP, it's my experience that S30V seems to hold a working edge longer but if both are polished, the XHP will hold that fine edge longer than S30V.
Try doubling the number of strokes going from brown to fine to UF rods each time you change grit. For example, 10 strokes per side on the brown, 20 per side on the fine, and 40 per side on the UF with the lightest contact that you can manage. You might like the results. :)
greencb
Postby greencb » Sat Jan 04, 2014 10:29 am
I have a PM2 in CTS-XHP it is my EDC. I sharpen with an edge pro and took the bevel to a 6k polish. I have used this edge for pheasant cleaning and I just processed a Deer this season with it, from field dress,skin, de bone and final meat prep this knife was used for it all in order to see how the steel would hold up. I did run the blade on a steel rod just prior to cleaning up backstrap for a few strokes. After it was all said and done I can still shave my arm with this blade. This edge had a year of edc on it I had cleaned probably 16 pheasants with it and processed a deer. I have used vg-10, ats-34 and zdp-189 I like this blade the best.
nozh2002
Postby nozh2002 » Sun Jan 05, 2014 3:16 am
In general all Carpenter steel are much better then Crucible. Even CPM S30V version made by Carpenter left original CPM S30V miles behind.
Think about this - on my opinion only way for Spyderco to make CPM S30V compete with CTS-XHP and CTS-204P is to ship those american
supersteels to Taiwan - across the Pacific and ship it back to US, otherwise no one even look at CPM S30V which is quite pathetic. Still even
with this shipments over Pacific I prefer CTS-XHP to any Crucible steel.
Set to be ignored by everybody.
Effectevely I am banned, but this is done the way nobody noticed, which means
Spyderco knows pretty well, that this ban is wrong and tries to hide that.
Made in USSR
http://nozh2002.blogspot.com/2011/07/ed ... sting.html
dbcad
Postby dbcad » Sun Jan 05, 2014 6:11 am
Welcome greencb :) Enjoy the forum :)
From your account I can infer the XHP holds a nice fine edge very well :) Did you happen to hit any bones during your processing??
Charlie
Mikael Andersson
Re:
Postby Mikael Andersson » Mon Aug 08, 2016 12:48 am
In that case Spyderco should really polish that blade on the Slysz Bowie. :D
Xplorer
Re: What is your opinion of CTS-XHP?
Postby Xplorer » Mon Aug 08, 2016 1:40 am
CTS-XHP is a great steel that's very similar to S30V.
Father of 2, nature explorer, custom knife maker and So. Cal native.
@Xplorer42 on Instagram.
Users browsing this forum: Enactive, Majestic-12 [Bot], MSN [Bot], pantagana23, RamZar, sn0wman72, stanolszews and 38 guests
