Best Replacement for Spyderco Medium Benchstone, Chosera 800 or Chosera 1000
Brian205
Postby Brian205 » Sat Dec 28, 2013 8:39 pm
Hi guys, just asking.
Sharpening setup.
Ordered - waiting for it to arrive.
Spyderco UltraFine 2x8
Spyderco Fine 2x8
I already have a Lansky Professional System
I want to try Chosera water Stones to cover my "Medium" Benchstone Setup.
Which should I buy.
Chosera 800 or Chosera 1000 ?
(other chosera lower grits are 400 and 600)
My goal is to conserve my knives steels. So I hone and strop when the edge is not that sharp anymore. And I try to keep away for coarser grits as much as possible.
Will the Chosera 800 or Chosera 1000 be a good replacement for the Spyderco Medium in my setup.
thanks :D
bpeezer
Postby bpeezer » Sat Dec 28, 2013 11:57 pm
I like the Chosera 1k stone, I use it between my 400 and 3k and I get fantastic results. The 1k has a good material removal rate, and I love how hard the stone is. I used to set my bevels with it before I got my 400 stone, so I think you should be ok with it as your medium.
rjowen0984
Postby rjowen0984 » Sun Dec 29, 2013 4:37 am
I really like my Chosera 1K. It is very well balanced, if you need to touch up it can take a decent amount of steel off or if you are VERY VERY light it polishes beautifully!
Brian205
Postby Brian205 » Sun Dec 29, 2013 1:44 pm
Thanks for the replies :)
Brian205
Postby Brian205 » Sun Dec 29, 2013 2:30 pm
I know both are High Quality stones :)
but between the Spyderco Medium Benchstone and Chosera 1000
a) Which Preserves and Saves your edge more ?
b) Which produce a better edge ?
c) Is the Spyderco Medium Benchstone a Better Lower Grit "Partner" of the Spyderco Fine and Ultrafine which I have ?
Thank your for the replies
Brian205
Postby Brian205 » Sun Jan 12, 2014 10:37 pm
anyone :)
Bill1170
Postby Bill1170 » Mon Jan 13, 2014 1:01 am
They are difficult to compare, apples and oranges, really. The waterstone has a weak binder so it cuts faster than the medium, but it also breaks down to form a finer grit slurry, giving you multiple grits from one stone. The brown medium Spyderco stone has very strong binder and won't cut as fast as the Chosera 1000 can. It will tend to load up and need cleaning to keep cutting the steel.
Users browsing this forum: 8-fingers, austrian_spyder_fan, Bing [Bot], darkjabroni, Google [Bot], niobiumcarbide, pantagana23, rklee and 50 guests
