Removing Ticks from Flesh?
- SpyderEdgeForever
There are wood ticks and there are deer ticks and I know Lyme Disease is carried by deer ticks, a very nasty disease. I know two people who have been permanently affected by it.
What are some good methods you all know about removing ticks safely? I know there are tweezers and you have to be careful so the head will not break off. I was told you can use a lighted match or lighter and when exposed to the tick, the tick will extricate itself on its own. Is this true?
What are some other methods?
- WireEdge Roger
Our dog picked up ticks frequently and our son loves to be in the woods, so I can tell you that in our experience nothing beats a good pair of tweezers. I'm not a fan of holding open flame to skin and the petroleum jelly method (covering the tick and waiting for it to die) doesn't work either as it just makes the tick more difficult to remove because they still won't back out.
We've also tried tick twisters that you can buy in pet stores and they've never worked for us either.
Bottom line is that it must be fully removed and tweezers with a solid grip, as close to the skin as you can get and a quick tug is the best method, at least in our experience.
I have pair that I purchased from County Comm and the tips are very sharp, precisely ground and they work very well for tick removal.
-Jodi
It's not just in my head, it's in my heart.
I used tweezers (past tense - haven't seen a tick since moving to Sequim) but found quick pulling to break off the head too often. Firm grip and medium constant pull until it lets go have worked for me.
RanCoWeAla
These are the best I've used for humans (not as good on dogs and cats).
http://www.ebay.co.uk/itm/OTOM-TICK-TWI ... 3a7929663e
They come in a pack with 2 different sizes so they work well on large and small ticks.
- Knivesinedc
The tweezers close as you can to the head with a medium pull works well, but never burn the tick!! The heat will cause the tick to throw up inside of you and give a highly increased chance of lyme disease. also the body could just fall of and leave the head lodged in your flesh causing the ticks fluids to run into your body. it sounds just lovely doesnt it?? :D
Relentless Perseverance in the Face of a Lightless Sky.
Joshua 1:9b "Be strong and courageous, do not be terrified, do not be discouraged, for the Lord your God will be with you wherever you go"
- SpyderEdgeForever
The spoon? I haven't watched the video or anything so I'm not sure ha. But if it is the tick spoon you are talking about then I must say that I and many coworkers have used them to remove ticks of all species and life stages.eric m. wrote:Cannot tell, but from the video it could have just decapitated the tick, leaving the head inside the dog's skin!
So many spydies, not enough pockets.
"No one else could ever be admitted here, since this gate was made only for you. I am now going to shut it." Before the Law, Franz Kafka
Spydernation #1990
Spydernation #1990
I just use my thumbnail and when I pull it off I make sure there is a little flap of skin that comes with it. Knife blade works if it is dull.
1) Ticks have no anal vent so if you flame them they regurgitate into you - that's a problem.
2) You need to watch the area in the case of a deer tick to see if a bullseye appears.
3) Use prevention- deet on the pants cuff and a tick check will help a great deal. If you have pets check them for grapes
- defenestrate
I have such a loathing for ticks I have tried most methods to get one out. typically I just use my fingers and have never had an issue. if I have feared infection I lean toward peroxide a little prodding with a knife tip or fire, or some combination thereof. I tend to incinerate ticks with a small torch lighter if plausible.
- xceptnl
Probably not the end all source for information, but here is what the CDC says.
http://www.cdc.gov/ticks/removing_a_tick.html
labixiaoxin
It is without any doubt that stockings are the sexy weapon to both men and women. When come to cool season many wholesale stockings are available online and store. Would you like to have a try on Shiying wholesale sexy lingerie online store? Visit now and enjoy the amazing low offer!
I second the O'TOM Tick Twister. My vet sells them at the clinic and they work very well. We use them on the dogs and on ourselves and we have never had a tick's head come off using this tool. The key is to twist the tick counter-clockwise. Apparently they bore into your skin with a clockwise rotation. By going the other way they are easily removed. We have tried every other method known to man and the Tick Twister is the only consistently good way to remove a tick. Its a life saver.
http://www.otom.com/how-to-remove-a-tick
