"Public friendly" small EDC
I have used both the Cat and the Dragonfly and given the choice i will take the Dragonfly every time. The Cats detent keeps the blade from closing smoothy.
My :spyder:'s : Sage 1, Native 4, Cricket, Dragonfly 2, Tenacious, Persistence Blue, Jason Breeden Rescue, Cat, Delica 4 Grey FFG, Renegade, CF Dodo, Orange Endura 4 FFG, Lum Chinese Folder
- this_is_nascar
As I've already suggested, based on your list, get the Dragonfly-2. That being said, if you want a really cool/working knife for less than $15, check out the Kershaw OD-2. It's an awesome, smallish, useful knife.
"The only way to stop a bad guy with a gun is a good guy with a gun". --- Wayne LaPierre 12/21/2012
I think I've decided to go for the DF2
now I'm trying to decide whether the ZDP-189 is worth the extra money,
better edge retention means harder to sharpen when you eventually need to, and I'm by no means good at it!
The other negative I could think of is that the ZDP-189 dragonfly seems to come in British Racing Green only,
or at least the ones I saw..
so yea..what do you guys think?
- Officer Gigglez
- Location: Originally out of Arizona, currently live in Missouri.
Probably can't go wrong with any of them. I personally would opt for the Dragonfly, but probably in H1 (not knocking VG10, just prefer the low maintenance of H1).
-Tenacious, Combo edge
-Tasman Salt, PE
-Persistence Blue, PE
-Pacific Salt, Black, PE
-Delica 4, Emerson Grey
-DiAlex Junior
-Byrd SS Crossbill, PE
-Endura 4 Emerson Grey
-Byrd Meadowlark 2 FRN, PE
-Resilience
-Tasman Salt, PE
-DiAlex Junior
-Resilience
I'd stay away from the ZDP if you don't feel confident in your sharpening ability. VG-10 is a wonderful steel and easier to maintain (sharpening, corrosion) than ZDP.Leon wrote:I think I've decided to go for the DF2
I recently got a ZDP-189 dragonfly as a present for a friend and it was seriously scary sharp out of box - I feel that ZDP-189 not only holds it's edge longer, it also seems to come sharper than VG-10 from the factory, IMO.Leon wrote:I think I've decided to go for the DF2
If you are a knife owner and user I feel that learning to sharpen is a basic and worthwhile skill to acquire, and getting a sharpmaker will take virtually all the guesswork out of it. The trick with ZDP-189, as with all hard knife steels, is to keep it touched up, much as you would the paint job on a nice car. Just a few strokes after a day's use will prevent it ever becoming so dull that a major sharpening project is needed.
I like the BRG - it's a very dark green and looks almost black under certain lighting.
All the best with your choice!
Regards,
Bruno
"Each of the builders wore his sword at his side as he worked." - Nehemiah 4:18
Bruno
- 3rdGenRigger
I have a Nishijin handled Dragonfly which has a ZDP-189 blade. I've now had to touch it up once, and the trick most here recommend really worked for me; light pressure and more strokes on the sharpmaker. I'm still amazed how long it went before needing a touch up, and it was easily my sharpest Spyderco right out of the box. It still slices paper more easily than any of my knives, though geometry etc. also plays some factor in that. I'm completely sold on ZDP, and I've done absolutely nothing to prevent corrosion with it other than making sure it's clean when I put it away, and no noticeable corrosion or patina yet.
All Glory To The Hypno-Toad
---> Branden
---> Branden
- phillipsted
- this_is_nascar
- jackknifeh
I only have the D'fly2 of the 3 you mentioned and it is a great little/big knife. Others have suggested other knives so I will too. I didn't read every post though. I LOVE the Manbug. I like it better than the D'fly for my small knife EDC. But since I also always have a bigger knife I can live with the smaller Manbug instead of the D'fly2. But if you only want to carry one knife the D'fly may be the better choice. The D'fly handle gives you a better grip for harder cutting chores like cutting thick cardboard. OTOH, the Manbug is one tough little knife and will handle much more than it's size would suggest. I also would say get the G-10 handle in whichever model you get. They have liners instead of just FRN. FRN is a GREAT handle material but I like the liners. They seem to give the knives a little more umph (technical, industry term :) ).
Jack
PS
Both are available with ZDP-189 blade steel.
Jack
PS
