What oil do you use?
- Officer Gigglez
- Location: Originally out of Arizona, currently live in Missouri.
Just curious as to what oil(s) everyone uses, as it occurred to me that maybe there is something better than what I use, which is Hoppe's #9 gun oil. Works well on both my firearms and knives. But my curiosity gets the best of me sometimes.
-Tenacious, Combo edge
-Tasman Salt, PE
-Persistence Blue, PE
-Pacific Salt, Black, PE
-Delica 4, Emerson Grey
-DiAlex Junior
-Byrd SS Crossbill, PE
-Endura 4 Emerson Grey
-Byrd Meadowlark 2 FRN, PE
-Resilience
-Tasman Salt, PE
-DiAlex Junior
-Resilience
- Officer Gigglez
The mineral oil I have for my whet stone(s) doesn't seem to soak into the steel. It just pools on top of it, like water.
-Tasman Salt, PE
-DiAlex Junior
-Resilience
-Tasman Salt, PE
-DiAlex Junior
-Resilience
- jackknifeh
Someone here does use Frog-lube. Don't remember who. I use Nano-oil on pivots and Tuf-Glide on blades and things for corrosion control. Tuf-Glide is an ok lube at best but great for fighting rust. Nano-oil is an outstanding lubricant, especially for places where a lot of pressure is required. Far more pressure than is in a knife pivot. So, IMO that makes it far better than needed (overkill) which is always good IMO. Not the cheapest oil but it lasts.
Jack
Jack
- salmonkiller
Yeah, Im getting that FinishLine grease once the CRK runs out. I want to try nano oil also for when I want to go with a fluid.
You guys should give Ballistol a shot. Great for firearms, blades, and treats most any metal. After some applications, it leaves a sort of finish to the blade, closest reaction I can think of that is similar is like how a cast iron pan is seasoned. Keeps corrosion off and is food safe.
I don't use very much oil but when I do I use plain old 3 in 1 oil. I had to learn the hard way that oil is the very worst thing you can possibly do for classic slip joints with Brass liners and natural handle materials. Oil attracts moisture thus the spots of rust that start to form on the top and bottom of the Brass liners. Also it will discolor Bone and Stag. I realize you don't have those things to worry about with Spyderco's but thought I might help someone prevent a huge disappointment someday. Use nothing but Renwax on the classics.
There's several of us who use FrogLube, it's a little pricey and a little bit goes a long, long way. I can vouch for Nano-oil also. It is somewhat expensive as lubes go. But you use it very sparingly. Under normal circumstances one vial should last, most of us, a lifetime. My favorite application for FrogLube is "seasoning" the liners of my Militaries. It's probably overkill to lube Spyders any at all, but I find satisfaction in using it.jackknifeh wrote:Someone here does use Frog-lube. Don't remember who. I use Nano-oil on pivots and Tuf-Glide on blades and things for corrosion control. Tuf-Glide is an ok lube at best but great for fighting rust. Nano-oil is an outstanding lubricant, especially for places where a lot of pressure is required. Far more pressure than is in a knife pivot. So, IMO that makes it far better than needed (overkill) which is always good IMO. Not the cheapest oil but it lasts.
Jack
What is truth? Pontius Pilate
- The Deacon
No lubricant at all most of the time, mineral oil on the rare occasions when I do.
- jackknifeh
Lots of products like that I bet. My wife when she was really young worked in a orange juice plant one summer. The huge vats of OJ were filling cans but the labels would change from one brand to another.DWW wrote:Mineral Oil.
I imagine a whole lot of different oils on the market by various companies are nothing more than mineral oil packaged with their company logo on it. I do know that Hoppes #9 lubricating oil is nothing more than plain old White mineral oil.
Jack
- mikerestivo
- WireEdge Roger
