PM2 or Southard Flipper
I'm thinking of buying a knife for myself for Christmas.I want a medium sized folder. I would primarily use it on weekends for general knife chores and hunting. Skinning and elk would be what I would consider "hard use." That, or cutting hay twine.
The PM2 and the Flipper are the two I'm thinking about. I have never seen either of these knives. No one carries them in the area I roam. I've only seen videos on 'Tube. I realize there is fair bit of difference between the two. I would probably be happy with a PM2 in S30V, but the Flipper offers a few things that I also like. With the scarcity of the PM2, it seems there is about $100 separating the two The S90V PM2 is still available, but it's more expensive and the Flipper and it's at my breaking point.
Is there anything similar expected to hit the street in this time frame?
I like flipper style knifes. It seems like the Southard Flipper's steel should be better than most available PM2s.
What about overall strength and long-term durability. If I fork out 240 bucks for a knife, I would expect it to last longer than me.
I have an EdgePro. It seems like a FFG would be easier to sharpen with this than the hollow ground Flipper?
I'd like to hear thoughts, experience or suggestions.
Why? They are both open construction and easily cleaned.PMBohol wrote:The PM2 would be easier to clean after gutting and skinning. It has a better clip for carry too.
The PM2 is a better slicer. I have both in 204P and if I could only have one, it would be the Southard due to the longer edge and blade geometry. It is definitely the better knife for cutting twine and, while most of my skinning experience has been watching my cousin do it, I'd prefer it for skinning a large animal as well. I also prefer it for cutting up apples and general kitchen duty. Also the flipper is fun.
- senorsquare
You can go wrong either way, but I've owned multiples of both and the Southards are gone and I still have a Para 2. I prefer the ergonomics and lighter weight of the PM2, not to mention that the Paramilitary 2 costs roughly half as much as the Southard. The Southard does come with CTS-204P, which is a helluva steel. The Domino would be a good in between consideration.
I have both, and like others have said, , you kind of can't go wrong either way but it's still an apples vs oranges kind of issue since they are so different. Personally, I like the Southard better, and believe it to be the finest knife Spyderco has ever produced. 204 steel is freaken awesome in a blade of this size and, for me, the ergos work great. I'm not a huge fan of the clip, but it works well enough so as to not detract from the knife overall. The Para2, , well it's just a go to workhorse and it probably gets more pocket-time with me than any of my Spydercos (I have 4 different Paras and only one Southard). I will also say that the Southard is a little more difficult to sharpen on the EdgePro, but the 204 takes such a sweet edge it is very well worth the trouble. I would agree with others that if this dilemma is causing you too much stress, ,then the Domino might be a good option.
