New to Spyderco--got bit by the bug
- moosedrool
Greetings!
I recently purchased Dragonfly2 (ZDP-189 FRN) & love the
little folder for light EDC. Typically I'm carrying both the D2
and Emerson/Protech auto CQC-7 for road trips/camping. I'm already
looking at my next Spyderco purchase in light of my positive
experience with D2! Any suggestions for my next Spyderco? Thinking
full flat ground, step up in size 3-3.5, carbon fiber or G10,
vg10/zdp189, & leaf shape non-serrated. 100-150 price
range. The new knife will fall in rotation when I'm wanting
a bit more than Dragonfly2 & not wanting to carry my automatic
Emerson CQC-7 (issue in out of state travel. my state allows
auto knives). The next Spyderco will likely be step towards
modest collection. Thanks for any input.
[ATTACH]22769[/ATTACH]
- jabba359
Welcome moosedrool! My first thought was the same as paladin's: the Caly 3/3.5, as it fits your price range as well as size, steel type (available in VG-10 or ZDP-189), grind, handle material (G-10 or CF), and blade shape.paladin wrote:Sounds like you would be looking for the Caly 3.5...believe it or not, it's just a smidge heavier than your Dragonfly 2 with a load more cutting power, well within your price range also. BTW, welcome...good folks here.
When i red your discription I also thought Caly 3 or 3.5, the CF version with ZDP is in that price range ($130-150). The Caly is a wicked cutter and a sweet EDC knife and of course the ZDP is a wonderfull steel :)
Current EDC: Techno, Squeak, Southard Flipper, Caly 3.5
New Arrivals: Chap3, Domino, Sage 3
2014 Wishlist: Yo2 CF, Deviant Friction, Tatanka, Tusk, Firefly
Oldies Wishlist: Delica CF PE, Civilian CF PE
- moosedrool
- GreatSyxsuke
I would reccomend the Caly as well. The good old standby Endura in G-10 may fit your bill as well and would be under your price range as well. Welcome to the forums, we always welcome new addicts. :)
Current carry: Spyderco Squeak or Spyderco Pingo (Back right pocket), Paramilitary 2 Black G10 (front right pocket)
Future wants: Karahawk
"It's far better to carry and never need than to not carry and desperately need."
- moosedrool
- jabba359
I've got a Caly 3 and have had no issues with the riveted construction. For some companies, the riveted build is a source of pride in the workmanship. I believe that one reason the Caly family is riveted is that the thin profile doesn't allow for screw-together construction, but I may be misremembering :rolleyes: . The blade has a screw, so it can be loosened or tightened to fit your likes. My Caly (like many others) came a bit gritty, but a quick flush with soapy water, rinse and dry had it working perfect. Keep in mind that out of the box the knife will likely be a bit tight, but with repeated use the parts will wear in a bit and loosen up a little, allowing for slicker blade deployment.
The decision between G-10 and CF is likely to be influenced by the blade steel you want: the ZDP blade comes in the CF handled knife while the G-10 handle is mated up with VG-10 steel. There is also a sprint run version with grey G-10 handles and Aogami Super Blue blade, if that is of any interest. It's a bit pricier and harder to find however. I don't think you can go wrong with any of the versions, however, as the Caly 3/3.5 is a fantastic knife.
I would go fro the CF, its only $30 more expensive then the G-10 version. And the ZDP and CF upgrade are certainly wurth $30.
The pinned construction does not pose any problems on my knives (I have 4 Caly 3 and 3 Caly 3.5) The rivets are only on to keep the knife together. The pivot is adjustable with a normal screw. Only the Clay 3 Damascus is not ajustable all the others are. So no issues with blade play.
- moosedrool
Yo moosedrool, they're biting me, too. Just got me a Dragonfly 2 G-10 and it suddenly needs company.
I'm close to Golden so I went looking at the Caly3 and Caly3.5. Great knives. The Caly3 is very nice and of course I must have one, but it is just a step up from the Dragonfly. so the Caly 3.5 makes a better choice for my second. Except I like the G-10 handle better than the carbon fiber version, but would rather have the ZDP from the CF on the G-10. But the knife I really wanted is the Sage 1 with the blue G-10 handles off the Sage 3 cause I'm not really into the button lock, And I really should go back and look at the Native5' s again cause those were pretty sweet.
Hope that helps.
Hope that helps.
As others have said you can't go wrong with the Caly 3-3.5 or Sage 1, all are great. I prefer the CF to the G-10 as it's easier on the pockets. The Caly's are mid back lock and the Sage 1 is a liner lock if that makes a difference. Currently my CF Caly 3.5 gets more carry time than all others. A LOT of knife that is relatively small, thin, and beautiful.
- moosedrool
Foghorne. Sounds like the ramblings of a mad man looking for knives but with underlying rationale. LOL. :) Thanks for input-makes it more fun.
""Yo moosedrool, they're biting me, too. Just got me a Dragonfly 2 G-10 and it suddenly needs company.
Hope that helps. ""
Hope that helps. ""
- moosedrool
