Show those Edges !!!!!
Clip
#541
Post by Clip »
Did you use diamond stones to reprofile that zirc?
Chris
kwakster
#542
Post by kwakster »
Removing the chips and setting the new bevel was done with a Tormek T7 fitted with an SB-250 Black Silicon stone, refining & convexing with a Paper Wheel coated with 15 micron diamond compound, and semi-polishing with a second Paper Wheel coated with 6 micron diamond compound.
I gotta be honest, I wasn't very impressed until I caught that it's ceramic. That's pretty awesome. I bet that thing holds that edge for a loooong time.
kwakster
#544
Post by kwakster »
Time will tell how long it will hold this sharpness (did some testing with it):
[video=youtube;R3-A0SMcIbw]http://www.youtube.com/watch?v=R3-A0SMcIbw[/video]
Also cut some toilet paper with it:
http://www.youtube.com/watch?v=Ubg_drYHoKE
http://www.youtube.com/watch?v=hUkKfwGFogY
http://www.youtube.com/watch?v=RSkxPA9BK8E
@ Donut: my camera is a General Electric E850
Senate
#545
Post by Senate »
^^impressive results
Alexandre.
Rwb1500
#546
Post by Rwb1500 »
Cheddarnut wrote:snagged a lavender LB, edge was chewed so i fixed it immediately.
Hey, Cheddarnut, what's that stuff on the bottom of your Bic? :D ;)
xceptnl
Post by xceptnl »
Senate wrote:^^impressive results
That was my first thought!
*Landon*
LC Kid
#548
Post by LC Kid »
Hi Mr. kwakster!
Your results are above awesomeness!
:D I've always found it tricky when trying to improve a ceramic edge to something below 20° inclusive. :rolleyes:
Stay Sharp!
kwakster
#549
Post by kwakster »
Hi LC Kid :-)
I haven't found a ceramic kitchen knife yet that will hold up to even careful daily use with a 20 degrees inclusive edge.
Currently testing an expensive white ceramic kitchen knife, but i already had to increase the edge angle from 25 degrees inclusive to 30 degrees inclusive because it kept microchipping at that angle, even during careful use on a good wooden cutting board.
The chips were so small they could only be seen through my magnifying glass, but they were there.
I have better hopes for this black knife, but the proof of the pudding is as always in the eating.
kwakster
#550
Post by kwakster »
Just finished sharpening this small ceramic backlock folder without any markings (probably made by Böker)
This well made knife had practically no edge and no point, and even opening mail with it was difficult.
The new edge fits in the 30 degrees inclusive slot on my Tormek angle gauge, is slightly convex, and can shave the hair on my leg in both directions.
I used the Tormek Black Silicon stone graded to around 1000 grit for reprofiling, followed by diamond compounds 15, 6, and 3 micron, all on dedicated Paper Wheels.
Specs:
Length open: 4.7 inch (12 cm)
Length closed: 3.0 inch (7,5 cm)
Blade material: black zirconium oxide
Blade length: 1.8 inch (4,5 cm)
Blade thickness: 2 mm
Handle material: Ivory Micarta & Nickel Silver bolsters
Weight: 61 grams
Seelow123
#551
Post by Seelow123 »
Bringing this thread back to life! No close up pics of the edge yet but you can see it in these pics.
"The world is a tragedy to those who feel, but a comedy to those who think"-Horace Walpole.
Clearcut
#552
Post by Clearcut »
Digi Cam Para 2 S30V, "Smurf" Para 2 M390, CTS-204p Para 2 , CF Stretch ZDP-189, Blue FFG Delica 4 VG-10
CRK Sebenza 21 Lefty
razorsharp
#553
Post by razorsharp »
jabba359
Post by jabba359 »
razorsharp wrote:[video]http://instagram.com/p/eQ-mnFx6yU/[/video]
Travis,
You're insane. In the best way possible. :p
-Kyle
-Kyle
:bug-red
http://www.spydiewiki.com
Holland
Post by Holland »
travis that is an amazing edge, thanks for sharing
Seelow123
#556
Post by Seelow123 »
That's Craziness Travis! You got some mean skills.
razorsharp
#557
Thanks guys ! Madrookies edges pushed me over the edge to get a EP. I can probably safely say my edges are like his now
w3tnz
#558
Post by w3tnz »
[video=youtube;Zr7Q2Aw76oY]http://www.youtube.com/watch?v=Zr7Q2Aw76oY[/video]
I see, said the blind man.
Holland
Post by Holland »
MadRookie
#560
Post by MadRookie »
razorsharp wrote:Thanks guys ! Madrookies edges pushed me over the edge to get a EP. I can probably safely say my edges are like his now
Yo Travis,
That is one **** awesome edge brother!!!
Well done!!
