Paramilitary 2 problem CTS-204p sprint
Here I thought that I was OCD, but I probably never would have noticed it.
- Buck Knives I Like
here's a tip. go out for a hike with your pm2, cut big branches into smaller branches. try your hardest to whittle a face in one. cut up your lunch. go outside in a thunderstorm with it and cut some sod or do some weeding.
not only will you appreciate the knife a lot more, those little imperfections will become unnoticeable.
GoodEyeSniper wrote:here's a tip. go out for a hike with your pm2, cut big branches into smaller branches. try your hardest to whittle a face in one. cut up your lunch. go outside in a thunderstorm with it and cut some sod or do some weeding.
I'd rather use the superblue delica coming out and just flip / stare at the para from KW, lol.
- donutsrule
