Paramilitary 2 problem CTS-204p sprint
- Buck Knives I Like
This is going to be hard to explain so i'll probably post pictures later, but i haven't been using my paramilitary at all its pretty much a safe queen, today i decided to pick it up and use it a little and it is beautiful.
However upon closer inspection there are some what honestly look like chips or divots or something on the edge of the metal liner, one on the top and one on the bottom liner
It just looks like the liner literally has 2 tiny holes at the very edge of the liner, maybe 1.5mm big if that, im not good with measurements but they are pretty tiny, where the metal meets the g10, i can't imagine its supposed to be this way,
i rarely use it its the sprint run g10, so cosmetic issues matter more to me with my safe queens
this sort of makes me a little annoyed, seeing as how the knife is perfect and I have yet to cut a single piece of paper with it until today, it's pretty much my favorite spyderco. both the holes im talking about are like jagged in nature too, they arent round circles and they are on the side of the liner where the blade closes in, If anyone knows what i'm talking about, if its normal, or if spyderco would do something about this i'd appreciate it. I'm way past any return date for the knife so I know KW wouldn't help me, and i love it too much to let it go over a cosmetic issue.
When I first got this knife I didn't notice this at all, I gave it the once over, no blade play, perfect blade placement when closed, and then put it away pretty much until now.
				Ferris Wheels
- kennethsime
You got a bad one, it's no good and normally you should just throw it out. Lucky for you though, I'm actually compiling a collection of bad spydies because I have a grudge against the company. You can feel free to send it to me, and I will make sure it gets what it deserves. PM for address.Buck Knives I Like wrote:This is going to be hard to explain so i'll probably post pictures later, but i haven't been using my paramilitary at all its pretty much a safe queen, today i decided to pick it up and use it a little and it is beautiful.
kennethsime wrote:You got a bad one, it's no good and normally you should just throw it out. Lucky for you though, I'm actually compiling a collection of bad spydies because I have a grudge against the company. You can feel free to send it to me, and I will make sure it gets what it deserves. PM for address.![]()
Something tells me you're trying to trick me...
Haha that is it! what the heck is it? the start of the lasers like the original poster said? i'm surprised you got it without the pictures. This is the only para 2 i own so far, my para 1 didn't have a liner to compare it to.gbelleh wrote:Do you mean like this? If so, it's perfectly normal and on all Para 2s.
- kennethsime
- razorsharp
- chuck_roxas45
When I got my first para 2, I noticed a bit of side to side play. With the way it cut, I soon started to disregard the side to side. Also, I did not examine it with a microscope because it cut well enough for me.
That's funny, mine has no side to side play, rock solid. Anyway,chuck_roxas45 wrote:When I got my first para 2, I noticed a bit of side to side play. With the way it cut, I soon started to disregard the side to side. Also, I did not examine it with a microscope because it cut well enough for me.
The thing is,
My mind can't help but seek perfection, and my definition of it.
There are more like me we exist everywhere.
I consider the trait a flaw within itself ironically.
I look at everything from knives, to quandaries, to people, to life, and much more with a " microscope. " I seek unrealistic perfection in everything, not just knives... and it can drive one more then mad. I don't mean keeping the tables clean, or my shoes tied, its actually quite the contrary... It's like an invisible madness, only I know.
Something imperfect to the rest may seem perfect to me, and more then usually, perfect to another would for some reason bother me, no matter what the object / thing was. It doesn't have to make sense, it just has to make sense to me.
I don't question anothers madness, or ever try to correct it.
- RadioactiveSpyder
