Hello all, I would like your recommendations for a good maker of sheaths for my incoming mule. He must be willing to ship to outside the States. Thanks.
Also, if you're adding scales to your mule, you're going to have to send the mule to the maker. Not sure if you're a DIY person, but it may be easier just to order a sheet of kydex to make your own sheath. It won't be pretty, but will be functional.
thurin wrote:Give Christina Gere a call. I'm not sure if she ships international.
SheathPro, Inc
Christina Gere
(303) 886-0834
Does she have an email address? It's much more convenient (12-hour time difference and up) than long-distance calls from here, and a lot less expensive too.
bchan wrote:Does she have an email address? It's much more convenient (12-hour time difference and up) than long-distance calls from here, and a lot less expensive too.
Minibear453 wrote:Also, if you're adding scales to your mule, you're going to have to send the mule to the maker. Not sure if you're a DIY person, but it may be easier just to order a sheet of kydex to make your own sheath. It won't be pretty, but will be functional.
