SE and PE for diving
Hi all,
I'm looking for a dive knife and for obvious reasons I want a spyderco. I guess that when you're hooked you're hooked (mind the pun).
So went looking for spyderco dive knife reviews I came arround these results review and to my surprise the plain edge performed just as good or even better then the SE. I always assumed that SE would out performe PE.
So i wondered what the experiences are here concerning SE and PE spyderco's cutting rope, nylon, monofiliment, typical fishing/marine stuf.
What is better SE or PE or does it have the same result. I'm talking about both the knives being sharp. I don't mind sharpening more or less it's kind of relaxing.
Dino
Dino
For a seagoing/wet/dive knife I'd always pick H1, and 99% of the time I'd go with SE, especially since Spyderco puts a generous PE tip on most of the SE blades. This way, detail cutting is not left out and you get the ferocious cutting ability of SE.
To add to xceptnl's exceptional recommendations, I'll throw in the discontinued models Aqua Salt and Caspian Salt:
Chris
Chris
- Knivesinedc
For diving and rafting, I would go with this one: http://www.amazon.com/Spyderco-Atlantic ... antic+salt
Relentless Perseverance in the Face of a Lightless Sky.
Joshua 1:9b "Be strong and courageous, do not be terrified, do not be discouraged, for the Lord your God will be with you wherever you go"
The Aqua Salts are some of my all-time favorite Spydies. I believe Sal designed this knife. If you can find one of these with black or yellow handle you won't be disappointed. Feels "just right" in the hand. A truly exceptional knife.... PE or SE and no rust. Pictures don't do it justice. The more you use it, the better it gets. Thank you Sal and Spyderco for a knife that has given me so much pleasure to use.
dino wrote:That is what i also assumed that is why these results surprised me (link lost in original post sorry)
review
Even with plastiki ropes the pe needed just as much pulls or less...
this is a somewhat silly review, as it only tests factory sharpness. when PE loses its bite, you're going to wish you had SE. stick with SE unless you need clean straight cuts. if you do, go PE, but realize that you'll have to maintain a sharper edge to get good results. H1 requires more edge maintenance than most other high-end steels. given that its hard to sharpen underwater, i'd go SE every time.
ps, i wouldnt consider titanium in any form a worthy cutlery metal.
I have made a number of dives with my Atlantic Salt. I like it because it fits into my shorty wetsuit pocket with nothing exposed (clip removed). It is easy to reach and deploy. I don't like anything on my dive gear that could catch on a line in zero vis, so it works for me.
"I am right 98% of the time, the other 3% I don't worry about"
