Cruwear Mule Finished!
ricechrispy
Post by ricechrispy »
Just finished making the handle for my Cruwear mule. For this one, I chose to use maroon linen micarta and black micarta pins. Pretty pleased with how it turned out. I was a little careless and there's a bite from my belt sander on the spine, but I'm not too worried about that since I plan on using this as a camping knife. Apparently Cruwear is decently stain resistant for being non-stainless. I tried to force a patina without any success. The picture was taken after I let it soak in a cup of apple cider vinegar for about 4 hours.
In chronological order:
Paramilitary 2, BD30P Manix 2, Delica 4, M390 Mule, XHP Military, Dragonfly 2, Woodcraft Mule, ZDP-189 Manbug, Cruwear Mule, Superleaf, Forum Native 5, Manix 2 XL, Endura 4
DRKBC
Post by DRKBC »
Really outstanding, beautiful job!
Kohbanang
Post by Kohbanang »
Very nice looks like a lot of sandpaper work.Awesome finish!
Thanks for show :)
ricechrispy
Thanks for the compliments. I did do a decent amount of sanding. Progressed up to 500 grit and then used black and then red rubbing compound with polishing wheels on my drill.
Cheddarnut
Post by Cheddarnut »
Nice job! So smooth! What did u use for the pins if you dont mind me asking...
"...is cabbage a better blue than cars that sing?" C.S.
jabba359
Post by jabba359 »
Cheddarnut wrote:Nice job! So smooth! What did u use for the pins if you dont mind me asking...
This.
ricechrispy wrote:For this one, I chose to use maroon linen micarta and black micarta pins.
-Kyle
:bug-red
http://www.spydiewiki.com
phillipsted
Post by phillipsted »
Looks fantastic, ricechrispy! Nicely done! (I love burgundy micarta...)
TedP
DM11
Post by DM11 »
Lookin good!
Hold Fast
David
BAL
Post by BAL »
very very nice ricechrispy. Thanks for sharing. Great work.
Pockets
Post by Pockets »
Pretty! The micarta pins are a nice touch.
Delica PE, Dragonfly Salt SE, Stretch SE, Manbug SE, Mule 16, Sage 1, black/satin PM2, Native 5
ricechrispy
Thanks, all!
Pockets wrote:Pretty! The micarta pins are a nice touch.
Thanks, Pockets. This is the second mule I've used micarta pins on and I really like them. I think they look great, and I like the fact that everything I'm sanding is equally hard. My first mule was Ipe (wood) with brass pins and I found I had very subtle high spots at each of the pins since they were harder than the surrounding wood.
OldSarSwmr
Post by OldSarSwmr »
Great job! That burgundy micarta is drool inducing.
:spyder:
Dan
Pockets
Post by Pockets »
ricechrispy wrote:Thanks, all!
I know what you mean; I've had that happen too. I don't recall having raised spots with small diameter pins, however.
araneae
Post by araneae »
Looks great, nice work!
-Nick
Last in: N5 Magnacut
jackknifeh
Post by jackknifeh »
Great job. I like the micarta pins as well. I may check on this when I put handles on another fixed blade. Are they actually pins or are they plugs with a steel pin in the middle? I sure do think micarta is hard enough to make pins out of. Either way, I like the looks of them.
I've made a few handles for paring and slicing kitchen knives. I only used pins on a couple of them. Do the pins make the handle stronger somehow? Or are they there mainly for appearance? Till now I've just used epoxy on all of them with no trouble. The knives don't get used hard though like a camping knife would.
Jack
jmh58
Post by jmh58 »
Looks good!! :) John
ominodipietra
Post by ominodipietra »
Looks great! I really like the final color too.
- Gabriele
Le montagne sono il principio e la fine di ogni scenario naturale.
http://ominodipietra.wordpress.com
On Edge
Post by On Edge »
Really nicely done. Beautiful knife.
"In theory, there is no difference between theory and practice ... In practice, there is."
ricechrispy
jackknifeh wrote:Great job. I like the micarta pins as well. I may check on this when I put handles on another fixed blade. Are they actually pins or are they plugs with a steel pin in the middle? I sure do think micarta is hard enough to make pins out of. Either way, I like the looks of them.
Jack
Hey Jack,
The pins are 3/16" micarta rod. Here's an image:
I'm by no means an expert, but I think the pins do add strength. It seems like they would help mitigate any shearing force that is put on the scales. I'm sure that metal pins would be somewhat stronger, but my understanding is that it doesn't really matter since they're not the weakest link (epoxy is).
ricechrispy
Alright, I got tired of looking at that terribly-lit photo I posted earlier, so I borrowed my wife's camera and took a much better photo of the Cruwear mule along with my two previous mule projects and a newly acquired Bark River Bravo 1.5.
