I think I got this knife back in 2001 or so. The Wegner was quite popular on the forums back then and the custom versions made by Phil Boguszewski were selling really well. I even read that this Wegner design was the ‘official’ tactical folder of the Gunsite institute. I was still into ‘tactical folders’ back then. Needless to say, I was sold and had to have one.
The Wegner didn’t turn out to be one of my favorite folders and I never carried it much. The handle design didn’t work for me, I disliked the knife’s weight and the opening hole was too small for me. I did like the curved blade and handle design. I even got the Ocelot later on which solved most of my ‘problems’ with the C48.
After cleaning and oiling the large Wegner, I found that the knife still works great. The action is smooth and lock-up is still excellent. The Wegner rode in my pocket all weekend and did all the cutting chores I could find.
The C48’s curved hollow ground blade is a great slicer for most small kitchen chores. It cut up onions, peppers, meat and potatoes like a champ. I could even get a little ‘rocking’ action with that curved blade. The Wegner’s blade is pretty thick all the way to the tip. Especially when you compare it to a full flat ground slicer like the Military, but in practical use this didn’t bother me. The hollow grind is very well done. The thick blade and tip inspired enough confidence to subject the blade to some twisting and turning when I had to ‘dismantle’ thick plastic packaging materials. It didn’t affect lockup or cause blade play. After three days of cutting paper, envelopes, fruit, meat, veggies, cardboard, plastic packaging etc… the knife got a little dull. There was still a good working edge, but the Wegner definitely couldn’t shave anymore. Sharpening was easy on the 40 degree setting of the Sharpmaker; one advantage of a ‘medium performance’ steel like ATS-34 (years ago ATS-34 was considered a high performance stainless though).
I found that the weight of the large Wegner didn’t bother me as much this time. In the years since the Wegner came out, I must have gotten used to carrying heavier spydies like the Chinook, Manix, PPT and the Lionspy. The texture of the G10 is really smooth. Back then, Spyderco didn’t use that extra glass-filled G10 they use now. It almost seems as smooth as non-patterned FRN.
The small opening hole still bothered me a bit, especially for a folder in this size. I had a few instances where I wanted to draw and open the knife and ‘misfired’. The grip still doesn’t quite match with my hand. I have the same problem with the Endura, that knife too doesn’t ‘click’ with my hand. I still don’t quite understand the full steel spacer. It adds lots of weight and I don’t quite get the functional need for this spacer in an otherwise refined design.
I realize that a future sprint run is extremely unlikely, as Wegner/Bladetech has launched its own line of production knives. The large “C48 design” is still prominent in their catalog. I love what they did with the design. To refine the C48, I too would suggest an ambidextrous lock, 4-way clip option and less weight. Oh wait; did I just describe a Stretch 2? The Stretch is very similar to the Wegner, but with better ergos, less weight and you can even get one in ZDP-189. The blade and tip won’t be as thick as on the Wegner though. I definitely recommend getting at least one folder with a sturdy tip in your ‘arsenal’. Spyderco makes some excellent folders in this category; the Techno and Lionspy come to mind. Those blades are probably even sturdier than the blade on the C48, while offering the same or better cutting performance.
