Problem with Techno's frame lock
Minibear453
Post by Minibear453 »
I think it's the friction between the tang and the lock. However, if the geometry of the tang is too steep, you won't be able to build up the friction, and the lock slides off.
Carry a sharp knife, and life will never be dull
J32A2
Post by J32A2 »
Mine is rock solid!
bayvillageidiot
Post by bayvillageidiot »
Mine's rock solid as well. It's dominated the rotation for the last couple months and seen a ton of use.
Still like new.
It's been a tough little son of a gun.
tvhaugen
Post by tvhaugen »
I love my Techno. Mine is as solid as a ROCK! Great knife with impeccable fit and finish and some serious heft for the size.
Zenith
Post by Zenith »
kiwispyder wrote:Mine does the same, I live with it for now but may buy another one later and give this one to a friend.
I did give mine a light sand on the 2 lock faces (vertically) with some fine sand paper and it helped a bit but still moves.
I can't disengage mine with my hands though.
Here's a video of mine.
http://www.youtube.com/watch?v=iOKM4_yrEjE
I have experienced this myself on some knives. What I found is that either the lockface area is dirty causing the lock to slip, there might not be enough tension on the lock spring, or one has to give the lock a few hard flicks in order to cause it to reset. Note, these problems are secondary and not caused by the angle of the lock face. I, personally call this a plateau of the lock, because I experienced once you get the lock to wear that 0.001 extra the problem goes away. It is however not something one would want in this lock design as a constant no matter where the lock is located.
Hopefully I can get hold of some makers and get their opinions.
Zenith
Post by Zenith »
Well, I got hold of a maker and he says that it seems the lock face is just past the adequate lock angle.
"Also, I think carbidizing the lock could also lead to this, the grippy nature of titanium actually helps stop this, two hard faces will want to slide past each other and probably too polished. But I think the angle was the problem here"
Therefore, the best recommendation would be.......to send it in for inspection. Everything else is just speculation.
