Problem with Techno's frame lock
I notice recently a little bit of up-and-down blade wiggle in my spyderco techno. When I put pressure on the spine of the blade using my hand the face of the lockup gets push far enough off of the tang of the blade lockup that it allows the blade to close a little bit, creating wiggle. But this is not the only problem, because when I increase the pressure on the spine of the blade the lockup failed. I want to know if this is a common issue and if I have to send my new spyderco techno for repair.
I'm sure they would agree if indeed it is deemed out of spec. That said anything can happen with a new product. Even low percentages can result on a dice toss.
We had a $52,000 2006 Ford F350 diesel that cme off the truck at the dealership. On startup it bent over half it's pushrods and needed a rebuild. Only 11 miles on the odometer.
If I understand correctly to what you're referring, that's not quite right. It does not need to be the case, and in fact usually is not the case for most knives, that the whole lock bar makes contact when looking at it from the side. Marthinus over on Bladeforums has a good set of quotes on the subject; here's one of them http://www.bladeforums.com/forums/showt ... st11049951 (in fact that whole thread is on this subject :) )Titanium wrote:I was looking to the part of the lockup that touches the tang of the blade and I saw that it doesn't make full contact with the knife´s tang. In other words, it seems that the geometry of the framelock is not correct and therefore it moves when putting some pressure to the spine of the blade
What I understand form Marthinus is that Titanium sticks to metals and it doesn't matter what contact angle you have in the framelock.
(Not to sound bad but you can be off some on contact angle and get by with it by using ti since it can make up for your shortfallings here whereas steel would just slide right off the contact. Steel will demand the contacts be spot on and if they are not well, you'll see locks sliding off the contact toward release easier than ti when the contact angle is not right)
So why do you think the framelock in spyderco techno moves when I put pressure using my hand to the spine of the blade?
kiwispyder
Mine does the same, I live with it for now but may buy another one later and give this one to a friend.
I did give mine a light sand on the 2 lock faces (vertically) with some fine sand paper and it helped a bit but still moves.
I can't disengage mine with my hands though.
Here's a video of mine.
http://www.youtube.com/watch?v=iOKM4_yrEjE
Is the same problem that I have. Actually I saw your video way before I bought my Spyderco Techno. Also I was reading a post in the forum “http://www.spyderco.com/forums/showthre ... lock/page2", which explains some of the characteristics of framelocks. One of the things I was reading said something about the angle of the lock and if the geometry was incorrect in the lock face the tang of the knife will slip.
Maybe you bent the lock out too far, and it won't sit tight enough now. I have a Camillus Cuda that does the same thing. (I don't know why I have it still - bad ergos, stupid assisted opening, expensive :mad: - from long ago) I don't remember opening it too far, but that is exactly what happened. Can you tell I don't like frame locks and liner locks?
- best wishes, Jazz.
Yea, but it was a Ford ;P
Blerv wrote:I'm sure they would agree if indeed it is deemed out of spec. That said anything can happen with a new product. Even low percentages can result on a dice toss.
Far better is it to dare mighty things, to win glorious triumphs, even though checkered by failure... than to rank with those poor spirits who neither enjoy nor suffer much, because they live in a gray twilight that knows not victory nor defeat.
Theodore Roosevelt
Theodore Roosevelt
From a design stand point, what's supposed keep the lock from sliding back off the tang? Is it lock bar pressure inwards or the geometry of the lock interface?
Dan (dsmegst)
:spyder:
:spyder:
:spyder:
:spyder:
