By t7a13h87 at 2012-08-24
beatlman87 wrote:
Very nice, beatlman! I'm tempted to try that myself using a different color scale. Did the final knife require any modifications or special work, or did the blade just "drop in?"
It dropped in perfectly! The only non perfect thing was a tiny bit of up and down play, and the very tip of the salt's balde was touching the FRN under the blade.
Nice! How solid is the lock-up? The Salt / Delica 3 has a shorter lock bar than the Delica 4 so you wouldn't have swapped the lock bars as well (as I did when I did my Lil Matriarch / D4 blade swap). If the blade / lock bar interface is perfect I can see myself putting coloured scales on a Salt (not wild about the yellow as the only other colour) and get the slightly longer handle as well.
The lock up had a tiny amount of up and down. Not enough I wouldn't use it, but you could hear it if you shook the knife. I also tried the same lock bar with a delica ffg balde and it had the same amount of play. I think that bar is only going to work perfectly with the balde it came with (delica wave)
The Delica 3 and Endura 3 series had solid FRN scales. The Delica 4 and Endura 4 series has steel liners on the inside of the scales. It makes sense to use the Delica 3/Endura 3 design to create the Salt series because it is much easier and cheaper to make them rust proof.jackknifeh wrote:Is there a difference in the liners and hardware in the salt knives? Are they more corrosion resistant than "standard" hardware?
Jack
What he said exactly, and the Salts are our last wonderful, linerless Spydies, so enjoy them. It does look cool, and I'm impressed, and amazed it fit right in, though.dialex wrote:Not very sure about this. The SS liners (and other SS hardware) used on regular Delicas deny the usefulness of an H1 blade.
