Used my Para 2 - Gray CTS-20CP for the surgery.
It felt just as strong as any other knife. I believe the thinner blade on a small knife makes it cut easier just like any knife. I wasn't using any side to side force so the thinness wasn't an issue. I was very happy with how the Jester handled. I also had a Sage1 on me but used the Jester as a sort of test for the knife. Keep in mind that the plastic I was cutting isn't real hard but it's not the easiest thing to cut especially with a wider blade. I would have had problems with the Sage1 becaue it is much thicker at the edge than the Jester or any hollow grind blade. So, I think the Jester was up to the task (and more). It is one knife that I'm glad I have even though the price for a little knife seems high at first. Sometimes a small tool is the right tool for the job.KardinalSyn wrote:The Jester has a 2mm thick blade right? How does it feel when you have held both the thicker and thinner blades, comparatively I mean. Does it feel lacking in anyway?
