so i found a knife on the ground the other day. i noticed it was a spyderco and i did some research. its an endura 4. g10 handle vg10 blade. i dont know much about them. it has small scratches on the blade. i also noticed it was very hard to find on the internet. how much is it worth. btw. heres a pic
http://www.cameroid.com/t/2bd7baea3d534 ... 605774216d
spyderco g10
- darkstar29
It would be worth more if it was new & you had the box but since you found it on the ground, I'm guessing maybe a hundred bucks or so. The G-10 Endura is discontinued and it is many people's favorite version of the Endura.
Spyderco's G-10: Great STuff for handles
I was more or less out of circulation when the G-10 Endura hit>> I deeply regret that too
But the newest folder I have is the C-60 Massad Ayoob Sprint remake with the G-10 handle and I can tell you that it's great handle material.
And I even liked the older generation G-10 even as far back as the original Renegade model (circa late 90s)>> but this new G-10 is truly some very superb handle material that I would recommend to anyone. As recent as that G-10 Endura was I suspect that's probably the same handle material or close to it.
I like G-10 for a multitude of reasons>> one being it's chemical & corrosion resistant. Not at all temperature sensative >> easy to clean and maintain and has superb grip/purchase on fixed blades or folders.
Just clean it every so often with Ballistol and it will last you indefinitely. I don't know where Spyderco gets theirs but I can assure you that it is not cheap material at all.
- knife nut404
