Some of you guys are a lot quicker than I am to get scales onto your Mules. :D So, I assume you sent that in...and I guess you are right about it not coming back into the wild. I suppose that if the scales weren't too roughed up, a refinish might be possible, but that seems unlikely.xavierdoc wrote:In order to provide a better "key" for the epoxy, most people rough sand the surface of the tang and "dremel" score lines into the metal (and often the scale material, too.
This was my Cruwear Mule after removing the scales.
I doubt it will turn up in the second release :D
Personally, I use screws...sometimes with epoxy in some of the voids in the tang, but never use epoxy by itself (because I don't trust glue alone), so have never felt the need to rough up the tang... :cool:
