flashlights
DCDesigns
Post by DCDesigns »
mines a four sevens preon 1, and its hooked to my wallet at all times.
d.2.the.p
Post by d.2.the.p »
I always keep a 4sevens Quark Mini 123 R5 Edition on my keys.
Tank
Post by Tank »
I always have an iTP A3 EOS upgraded on me, Keep a Fenix L2D in my back pack and around the house I have a couple of Zebra lights. I use them quite often for a number of differnt things in a day. Plus those around me know that along with a knife I have a light so I'm kinda the go to guy for both.
-John
Blerv
Post by Blerv »
Rwb1500 wrote:A Surefire of some sort, anodized aluminum. The things are **** near unbreakable. I've accumulated a few of them, weapons lights too. Also a Streamlight on my keys, I think it's called the Micro? Excellent little led for its size and weight.
Anybody have any good suggestions for a small AAA light?
It's really hard to beat a 4Sevens Preon1/2. They have a high CRI sprint now for you incan lovers :) .
Echo63
Post by Echo63 »
I have a light with me nearly 24/7 (i dont carry one in the shower or whilst swimming)
I carry a Titanium Muyshondt Neutral Aeon on a neck lanyard
a Novatac EDC 120P in a belt holster (or a pocket if im just lounging around without a belt)
and a Surefire 9P - Bored for 18500 cells and Re-Anodized (a stunning looking dark green HA-3) with a Moddoo Neutral Triple and 2x AW 18500 cells
so i have a a long runtime/low output backup light (Aeon - 10lumens for 40 hrs or 100lumens for an hour and a half)
a every day light (Novatac - anything from 1lumen to 120) with reasonable runtime (30 mins on max, but it gets better quickly as you drop through the levels)
and a Big Bruiser - it only runs for an hour (1000 Lumens) and gets very hot, and it doesnt throw very far (50-100m is about it) but it floods the area with light
9P
Belt pouch for Novatac
T1A Titan (old edc - retired for the Aeon) TI Aeon, and Novatac 120p
If im working at night, i will generally throw my Maxabeam into the car
Throwing 1km over the river in Perth
power is nothing without control
bartvdb
Post by bartvdb »
fenix ld01 greeetzzz
Post by The Deacon »
Carry a Streamlight Twin Task when walking Bear at night so that we can avoid things that need to be avoided and so I can clean up after him when necessary. Still thinking of getting something a bit more powerful, but everything I read about seems to be either super powerful or extremely complicated.
NYRich
Post by NYRich »
knife nut404 wrote:i just got the fenix ld20 to day. never carryed a flsh light before till i ended up needing it so no i am perpared.
After the Maglite, the LD20's adjustments seemed a little fiddly, but once I understood the two bezel positions, it all fell into place.
Donut
Post by Donut »
The Deacon wrote:Carry a Streamlight Twin Task when walking Bear at night so that we can avoid things that need to be avoided and so I can clean up after him when necessary. Still thinking of getting something a bit more powerful, but everything I read about seems to be either super powerful or extremely complicated.
I really think you should try one of the Nitecore EX/DX line. It is no more complicated than you want it to be.
If you would like me to send you two or three lights to try out, I would be more than willing to do that.
-Brian
A distinguished lurker.
I regularly carry a 4Sevens Preon Revo 2 SS.
Its very useful for those mundane everyday tasks. One day it will save my life!
clovisc
Post by clovisc »
Fenix LD15 in my pocket, and a Fenix E01 on my keychain. I like them because of their small size, and because the AA and AAA batteries are easy to find. Flashlights are a necessity for the dark Alaskan winter.
:spyder: :spyder: :spyder:
bh49
#32
Post by bh49 »
I carry Novatac 120T for few years now. Just in case if I need it. It is small enough to fit into pocket and can produce a lot of power if you need it. Also I have surefire 6PL in a car.
Rwb1500
#33
Post by Rwb1500 »
Blerv wrote:It's really hard to beat a 4Sevens Preon1/2. They have a high CRI sprint now for you incan lovers :) .
Will be sure to check that out, like, now-ish. Thanks!
Azwaiian
#34
Post by Azwaiian »
I just bought another flashlight, this one is a Fenix E21, with only two outputs of brightness. The high is 150 lumens and the low is 48 lumens. It's just a twist of the head to go from one to the other, best part it's only $35.00 at Knifeworks.com.
I own a bunch more lights, but I like the idea of a simple two AA light. Hope this helps. :D
NoFair
#35
Post by NoFair »
They don't have to be. These are simple; push the button for on/off. Twist the control ring for whatever brightness you want (just like the volume control on a stereo).
1AA: http://www.batteryjunction.com/sunwayman-v10a-r5.html
2AA: http://www.batteryjunction.com/sunwayman-v20a-r5.html
Both work best on rechargeable batteries, but alkalines are fine if you don't run them on max a lot.
jackknifeh
#36
Post by jackknifeh »
I recently got interested in little flashlights. I'm amazed at how much light the little ones put out these days. I've used a mini-maglight for about 20 years and a couple years ago bought a 1 watt LED bulb and IQ switch giving it different brightnesses. Now I've gotten a Fenix LD01 (single AAA) and a Fenix E11 (single AA). My next purchase will be a Fenix LD40 but that's later. I carry the LD01 connected to a Ladybug salt or Kiwi (Kiwi at the moment) and have it all the time. I can walk my dog with that single AAA light and not even use the brightest setting. It's great. The E11 is nice too, simple and cheap. Only has two settings but I don't need the lights that will do 100 things. :) I wish it had a pocket clip though. Does anyone know where I can pick up just pocket clips? I also bought a cheap charger for AA and AAA batteries. I want to get a bigger better one later.
Jack
Blerv
#37
Post by Blerv »
Hey Paul.
You might consider something from Peak LED like the Eiger (AAA) or Logan (CR123/RCR123/AA/14500/17500, etc):
http://www.em-mgt.com/LED/Eiger.html
http://www.em-mgt.com/LED/Logan.html
They are USA made and very simple lights available in SS, Alum, Brass and Titanium. They are available in various carry configurations (short, keychain, momentary on button) and LED's (warm, cool, narrow and wide optics) but Bob over there could help dial it down for your needs.
The one I'm thinking of perhaps for you is the QTC model. It stands for, "Quantum Tunnelling Composite" which is basically a material that conducts current the more it's compressed. This doesn't give an "on/off" light but rather a twist from dim to full brightness with almost an infinite range of increments. The ones with momentary switches ramp up with thumb pressure.
With a rechargeable lithium you could have a .01 lumen-300lumen light without all the fussy modes to screw with. Here's a Youtube vid of the Logan: http://www.youtube.com/watch?v=a7LfEE6Bx-M
As a general disclaimer I think they are designed mostly for lithium batteries with nipples. As mentioned someone like Bob knows the ins and outs. I've got one ordered for Christmas :) .
BAL
#38
Post by BAL »
An Insight HX 150 or HX 120 is always in my pocket. There is never a day when I don't regularly use one. I have attached a URD (ultimate retention device) to both of them.
Attached is a link. http://www.rogueelite.net/product_p/urd-01.htm
It adds a little size to the flashlight, but after you get used to it, you wouldn't have a flashlight without it. I live on a farm and have unwanted critters that appear in the barn when it's dark. Mr. Glock and an Insight with URD makes a great set to handle the situation.
jackknifeh
#39
BAL wrote:An Insight HX 150 or HX 120 is always in my pocket. There is never a day when I don't regularly use one. I have attached a URD (ultimate retention device) to both of them. Attached is a link. http://www.rogueelite.net/product_p/urd-01.htm
I have found also that I use a flashlight every day multiple times. People who don't carry one will say "why, what do you use it for?" It's the same for people who don't carry a pocket knife and then start. Normally after they carry a knife for a while they wonder how they got along without one. Same for the pocket light IMO.
I got a cheap 100 lumen AA light for my wife on ebay. It is very bright and zooms in and out by sliding the head forward and back. It feels cheap and won't last for years but for $7 and free shipping it can't be beat. Also, my wife isn't worth much more than $7. :D Did I type that out loud??? :D I may be stupid (may be??? :) ) but I prefer the tools of better quality, durability and endurance.
Jack
Bert T
#40
Post by Bert T »
"...but I prefer the tools of better quality, durability and endurance."
Jack
In my 75+ years I have learned that almost without fail dollar amount for a product determines quality, durability and endurance.
Bert
