ikbs or similar spuderco
drewskeez
Post by drewskeez »
So I recently got a crkt ripple that has ikbs and it got me thinking crkt and zt are going to have a ball bearing knife but I would love to see a spyderco with something like ikbs and was wondering would any one else want one? Also what are the chances of this happening maybe with the tuff?
dialex
Post by dialex »
In a balisong yes, I see the usefullness of the IKBS but for a regular, side opening folder, honestly not. If I were to choose, I would much rather preffer a bushing like there is at the Sebenza. Although Spyderco linerlocks and complocks already have a smooth action more than enough for my needs.
Onionman
Post by Onionman »
If Spyderco is developing a folding knife with a flipper, I think the IKBS is a must! I have a crkt ripple and an eros, and the action is so smooth when using the flipper. On knifes without a flipper I don't see the point of using the IKBS.
The important thing was that I had an onion tied to my belt, which was the style at the time. You couldn't get white onions, because of the war. The only thing you could get was those big yellow ones...
hunterseeker5
Post by hunterseeker5 »
For a flipper knife I agree that bearings might be nice, but to be honest spyderco's bushing system is also stunningly smooth and solid but much harder to foul. You're going to have a hard time convincing me that bearings can match the bushing system for reliability and my Para2s are all so smooth...... *shrug* It doesn't feel like a bearing, but its still so smooth the blade will just fall open or closed.
jackknifeh
Post by jackknifeh »
I'd like to have a flipper knife but I don't know if Spuderco would make one, being an alternative opening method and the opening hole is their symbol. That would be up to Spuderco of course.
:D :D :D
Jack
mattman
Post by mattman »
Is this the new french-fry cutter division??
:D :p
VashHash
Post by VashHash »
Someone beat me to the potatoe punchline. Never thought about putting bearings in potatoes. I wouldn't mind trying a spyderco with ikbs. just have to have a **** of a detent or backspring to keep it closed.
nightburn
Post by nightburn »
The Spyderco Spuderco, now even better at peeling potatoes!
jackknifeh
I can't believe you guys are making fun of an innocent spelling error. Shame. :)
Jack
jossta
Post by jossta »
jackknifeh wrote:I'd like to have a flipper knife but I don't know if Spuderco would make one, being an alternative opening method and the opening hole is their symbol. That would be up to Spuderco of course.
:D :D :D
Jack
Hopefully they'll make the Southard collab. Either way, they at least have considered or the wouldn't keep showing it. Nothing wrong with having a hole and a flipper.
Bill1170
Post by Bill1170 »
If they made a flipper knife with the trademark hole, but put the hole in the flipper, would it still count as the trademark? Spyderco already has fixed blades with a hole for the trademark purposes. A flipper is, after all, a part of the blade.
Bradley
Post by Bradley »
I think the hole has to be at a certain location in the blade.
There is much to be learned from one who never speaks
Post by The Deacon »
Bill1170 wrote:If they made a flipper knife with the trademark hole, but put the hole in the flipper, would it still count as the trademark? Spyderco already has fixed blades with a hole for the trademark purposes. A flipper is, after all, a part of the blade.
Don't most flipper equipped knives have an alternate opener for those times when discretion is more desirable than flamboyance?
hunterseeker5
The Deacon wrote:Don't most flipper equipped knives have an alternate opener for those times when discretion is more desirable than flamboyance?
Nope. Most of them have impotent or non-existent alternate opening methods. Just take a quick glance down the Kershaw product line for example and you'll immediately realize....... :p Even their big deal knives like the 0301 the "thumb studs" basically only exist as a blade stop. Try deploying that knife with the thumb studs. If you ever do put is past the retaining spring the assist will almost certainly yank the blade away from your thumb and "flamboyantly" deploy it anyway. They just weren't designed with slow deployment in mind. If you do want to deploy gently on most flippers you have to gently push past the detent and then hold/move it by pressing your thumb against the blade where the spyderhole should be. ;)
Brad S.
Post by Brad S. »
Not all do, but thats the method I prefer. I often find myself in crowds or places where the WHAP of a flipper would be a bad thing, or less desirable, and I really enjoy thumbing open the folder with a stud, or a hole.
Brad Southard
Southard Knives
Now taking preorders. Lots of snob steel print run potential in this one. ;)
Sorry man, not making fun of you or anything...that gave me a good laugh :D
The Southard design has a flipper and a hole and both work well. Brad opted for a bearing system but with a bearing shell.
