i thought i'd add some work in progress pics in case anyone wants to try this for themselves :D .
First some pics of the wood, i took them real quickly outside, they don't do the wood justice.
next i outline where i am going to cut the wood for the handles.
next i cut the wood, you'll notice i went outside of the lines, just in case you screw something up when cutting, you will have enough room to fix it hopefully.
here i just placed the cut handles over the knife to get an idea of what the finished product will look like.
OK, here i used my dremel and cut out around the pins. it took about 15 minutes.
i heated up the end of the knife with a heat gun and tried to pry the corner off.
Now that i know the heat would work in getting the scale off i took off both sides. i was surprised to see all the rust, i am pretty anal about drying my kitchen knives after i wash them. maybe the glue that was used to hold the handles down was water based??
