Comparison between FFG Endura and Military:
![Image](https://lh3.googleusercontent.com/-4iCBLnTjJwE/TlxtRhmogQI/AAAAAAAAB2U/dHla2EN4OVc/s800/sm0216DSC_2120.jpg)
![Image](https://lh4.googleusercontent.com/-sHDs_hvrhFk/TlxtRo3FCaI/AAAAAAAAB2Q/agMAPuMRCZw/s800/sm0217DSC_2122.jpg)
Blade stock thickness comparison vs. a H1 Ladybug. It has a very thin blade and really would not hold up to any hard use. When I first picked it up, I naturally tested to see if there was any blade play. At first ii mistook the flex in the blade as play.
![Image](https://lh5.googleusercontent.com/-RLWMllFT-IE/TlxtSun6AeI/AAAAAAAAB2w/6wBJ0wdO5W0/s800/sm0224DSC_2140.jpg)
![Image](https://lh6.googleusercontent.com/-1K2jczCmkys/TlxtT18S3iI/AAAAAAAAB3A/UaW6SFgC-L8/s576/sm0231DSC_2153.jpg)
I noticed when I first got the knife that the blade is noticeably more thin then the locking bar and there's a visible gap between the FRN and the blade. Though there is no noticeable blade play.
![Image](https://lh6.googleusercontent.com/-xjf-sGDVpKo/TlxtSxA-fqI/AAAAAAAAB2o/TBZnc81RRd4/s800/sm0225DSC_2142.jpg)
This thing has a rediclously thin tip! Great for precise work but again, if thi knife is used for something other it's intended use you run a very high risk of breaking the tip.
![Image](https://lh4.googleusercontent.com/-KU-Rwmk4xRM/TlxtTaD--mI/AAAAAAAAB24/mJ2EK4oFVqI/s576/sm0230DSC_2151.jpg)
