I am not Kiwi fan, but I will buy this one. 2mm stock will be a big plus or at least 2.5 like original.The Deacon wrote:Sal, my first choice would be a blade with a smoothly arced spine and full flat grind mated with a bolster and scales handle.
[CENTER][/CENTER]
Larger Kiwi
Here you go:
1. Blade spine as a smooth warnie (a-la-Deacon) or notched like the original?
Notched.
2. Bolsters or full scales?
Bolsters
3. Hollow or flat grind?
Flat
Blade Steel.
Upgrade to S90v. :D
Start a new series with the new size. (Bolsters allow more materials to be used)
Trust me!
Notched.
Bolsters
Flat
Blade Steel.
Upgrade to S90v. :D
Trust me!
More S90v & CF please.......
1. notched
2. Bolsters or full scales: keep it thin....like the all original SS
3. Hollow or flat grind: flat since its larger
low rider clip
larger lanyard hole (or a removable clip fit in the lanyard hole)
low rider clip
I see the atoms free and fine,That bubble like a sparkling wine; I see the songs Electrons sing,Jumping from ring to outer ring;
-Lister
-Lister
yablanowitz
Notched, bolstered and flat grind would be my preference. I'd like to see 2mm or thinner stock as well. I see no point in building a gentleman's knife out of battleax stock.sal wrote:As a result of requests from afi's, we have a design for a larger Kiwi. Just under 3" in blade length. Mid-Lock-back like the original. Will be higher line like the original and made in Seki by the Kiwi maker. Have somed Q's.
- The Mentaculous
Ooh, I like this idea! My vote is for the original Kiwi blade shape..I think it's a great shape, both aesthetically and functionally (I love having that thin tip).
I vote for no boye dent, just a smooth line
Notched blade type, like the original
I vote for bolsters with an inlay like the originals as well.
Grind isn't important to me, although if you go with a hollow ground, a higher one would be nice.
- mark greenman
1. Notched
2. Full scales- no bolsters, please!
3. FULL FLAT GRIND !!!
Keep it notched to retain its original, unique, comical look.
Bolsters just wouldn't look right on a larger folder IMO and scratch easily.
And the thick hallow ground blade on the first one is the only reason I don't carry mine anymore. Let's make it a slicer!!! FFG is a must!
Excellent idea!
Excellent idea!
Hmmm...
I would say notched if it still allows you to get a finger up on the blade like the smaller one, but if not then Deacon style.
I'd go for bolsters-preferably front only but double bolsters are fine too. No full scales, we already have enough of those.
The grind? Flat, definitely, and with thin stock (as thin as is possible). The biggest letdown on the current Kiwi is the thick edge.
- Mr Blonde
1. Notched, it's part of the original Kiwi's character and it's functional. It's where I 'get a grip' on the blade's spine with either thumb or index finger.sal wrote:1. Blade spine as a smooth warnie (a-la-Deacon) or notched like the original?
2. Bolsters.
3. Hollow grind, the original Kiwi has a stout little blade I'm glad I had that much steel near the tip and on the spine for some 'cutting' tasks.
I don't know why that would be the case. I think so long as it has liners you could just about put any scale on it you wanted. It might even make it easier to swap scales for those of us who are not quite as mechanically inclined. Some people may not know this, but SFSW has made a no bolstered version of the original Kiwi before. Looked very nice!MCM wrote:The no bolster model would limit scale selection to G-10, CF & Micarta right?
What made these so cool was all the scale possibilities between the bolsters.
Food for thought..........
I like the idea very much. I find the Kiwi pattern useful, and have two of the original pattern in CF. I'd like the Deacon style, with or without bolsters - but the bolster pattern is very nice. I would find it hard to pass on this one with bolsters.
I would be fine with either style of blade. I can see a flat grind working well for most people.
1) Smooth warnie (as Deacon's picture)sal wrote:As a result of requests from afi's, we have a design for a larger Kiwi. Just under 3" in blade length. Mid-Lock-back like the original. Will be higher line like the original and made in Seki by the Kiwi maker. Have somed Q's.
2) Full scales
3) Flat grind
I would like the above, in a package similair to the G-10 75mm persian
[/CENTER]
