Detent question
tkdiver1
Detent question
Post by tkdiver1 »
I was noticing that on my g10 military that I can flick it open without even putting my thumb on the blade at all. Is that normal? It seems to me the detent should be a little stronger. Can any of you do this? Also consider that I am not trying extra hard to make this happen. I am simply flicking my wrist with a medium type flick and opens all the way up and the lock engages. Any insight would be much appreciated.
Dankerz
Post by Dankerz »
That's strange. I thought my military has too strong of a detent that makes it hard to open.
tkdiver1
Post by tkdiver1 »
Dankerz wrote:That's strange. I thought my military has too strong of a detent that makes it hard to open.
So then you are unable to flick your open like I can?
chuck_roxas45
Post by chuck_roxas45 »
Not with mine either. Maybe you have your pivot so loose that the detent is not working as it should. I'd tighten that up.
tkdiver1
Post by tkdiver1 »
chuck_roxas45 wrote:Not with mine either. Maybe you have your pivot so loose that the detent is not working as it should. I'd tighten that up.
That helped a little, but it still seems a little easy to open.
yablanowitz
Post by yablanowitz »
They vary some from piece to piece and from run to run. My beater S90V Millie has a strong detent, to the point where it nearly requires two hands to open. Some of my others can be flicked open fairly easily.
chuck_roxas45
tkdiver1 wrote:That helped a little, but it still seems a little easy to open.
Is that a new one?
tkdiver1
Post by tkdiver1 »
chuck_roxas45 wrote:Is that a new one?
Fairly new. About 2 months.
chuck_roxas45
You should ask someone from Spyderco about that. Seems to be an accident waiting to happen.
Post by The Deacon »
Ok, you've had it for two months. Next question would be how old it actually is, since knives have a long shelf life. In my experience, Militarys made in the past year or so have considerably stronger detents than older ones, perhaps in response to the changing legal climate. In contrast, those made prior to 2008 have comparatively weak detents, some so weak that they behave as yours does. Do you have the box? If so there's a two letter code on the label, to the right of the barcode. First letter represents the month, second the year, A = 1, B = 2, and so on.
tkdiver1
Post by tkdiver1 »
The Deacon wrote:Ok, you've had it for two months. Next question would be how old it actually is, since knives have a long shelf life. In my experience, Militarys made in the past year or so have considerably stronger detents than older ones, perhaps in response to the changing legal climate. In contrast, those made prior to 2008 have comparatively weak detents, some so weak that they behave as yours does. Do you have the box? If so there's a two letter code on the label, to the right of the barcode. First letter represents the month, second the year, A = 1, B = 2, and so on.
HJ August 2010 then. Do you think I should send it in then Deacon or just not worry about it. I honestly dont really see it being a big problem but noticed how much easier it was to open that my other knives and began to wonder. Thoughts?
rycen
Post by rycen »
If you turn the knife over and give it a shake does it open?
We would rather be the knife in your pocket, because is "works" better, than the knife in your showcase, because it "looks" better.
tkdiver1
Post by tkdiver1 »
rycen wrote:If you turn the knife over and give it a shake does it open?
yes
Definitely send it in.
rycen
Post by rycen »
If you don't like the way it is sound like you need to send in.
spyderdog
Post by spyderdog »
tkdiver1 wrote:yes
if it's that loose, I'd be concerned about it opening when you don't want it to.....like in the pocket
jackknifeh
Post by jackknifeh »
If I'm not mistaken, being able to flick it open one handed without touching the blade qualifies it as a gravity knife and very illegal in some areas. That's my understanding anyway.
Jack
pwet
Post by pwet »
then most of my knives are gravity knives. the only knives i cant wrist flick open are my 3 milies and my stretch for different reasons,
redyps04
Post by redyps04 »
Wow, I'm actually kind of amazed to hear this. It is equally as bad, if not worse, on both my Sage and my D2 Para. I just figured this was normal- even though my Ti Lum is a little better. I can open my sage just by putting very slight pressure on the blade without using the hole, and if I drop it on the carpet the blade comes flying out.
I guess I should send mine in as well, but really done want to have to do without it for that long.
ChrisM
Post by ChrisM »
Maybe be the detent ball has worn flat. It shouldn't be on a new knife but the ball on my orange military was worn almost completely flat in about 3-4 months. I guess it's possible out of thousands of them a few might not get heat treated properly, right?
