Detent question
Detent question
I was noticing that on my g10 military that I can flick it open without even putting my thumb on the blade at all. Is that normal? It seems to me the detent should be a little stronger. Can any of you do this? Also consider that I am not trying extra hard to make this happen. I am simply flicking my wrist with a medium type flick and opens all the way up and the lock engages. Any insight would be much appreciated.
- chuck_roxas45
Not with mine either. Maybe you have your pivot so loose that the detent is not working as it should. I'd tighten that up.
yablanowitz
- chuck_roxas45
Is that a new one?tkdiver1 wrote:That helped a little, but it still seems a little easy to open.
- chuck_roxas45
You should ask someone from Spyderco about that. Seems to be an accident waiting to happen.
- The Deacon
Ok, you've had it for two months. Next question would be how old it actually is, since knives have a long shelf life. In my experience, Militarys made in the past year or so have considerably stronger detents than older ones, perhaps in response to the changing legal climate. In contrast, those made prior to 2008 have comparatively weak detents, some so weak that they behave as yours does. Do you have the box? If so there's a two letter code on the label, to the right of the barcode. First letter represents the month, second the year, A = 1, B = 2, and so on.
HJ August 2010 then. Do you think I should send it in then Deacon or just not worry about it. I honestly dont really see it being a big problem but noticed how much easier it was to open that my other knives and began to wonder. Thoughts?The Deacon wrote:Ok, you've had it for two months. Next question would be how old it actually is, since knives have a long shelf life. In my experience, Militarys made in the past year or so have considerably stronger detents than older ones, perhaps in response to the changing legal climate. In contrast, those made prior to 2008 have comparatively weak detents, some so weak that they behave as yours does. Do you have the box? If so there's a two letter code on the label, to the right of the barcode. First letter represents the month, second the year, A = 1, B = 2, and so on.
- The Deacon
Definitely send it in.
- jackknifeh
Wow, I'm actually kind of amazed to hear this. It is equally as bad, if not worse, on both my Sage and my D2 Para. I just figured this was normal- even though my Ti Lum is a little better. I can open my sage just by putting very slight pressure on the blade without using the hole, and if I drop it on the carpet the blade comes flying out.
I guess I should send mine in as well, but really done want to have to do without it for that long.
