Manix 2 lock fails hard-use test [VID] -- thoughts?
jylong_away
#381
Post by jylong_away »
sal wrote:Hi guys,
While we appreciate the support, we prefer not to try to discredit competitors on the Spyderco forums. Your cooperation is appreciated.
thanx.
As far as the Manix, there will be some adjustments made to the ball travel on the ramp. I don't think it's anhything you will be able to see, but the changes permit the model to take Mr. Ankerson's "overstrike test" and not defeat.
We broke many samples of the Manix to study this question. We were able to duplicate the break and we're making adjustments. We were not able to duplicate the damage done to the knife in the amount of strikes indicated. We could get the tang to deform and coin, like Mr. Ankerrsons sample, but it took far more strikes than the 5 shown.
We were able to duplicate the damage done to the tang and the liners, but not without taking the knife apart, relocating the ball and re-striking.
We have many thousands of Manix2 models all over the world performing hard use cutting daily, with no complaints.
Thanks for the update sir!
Could I inquire - Is the 'ramp' the channel cut into the backspacer which the ball travels in? Or is it referring to the portion of the blade tang that the ball contacts?
Dave
#382
jylong_away wrote:Thanks for the update sir!
Dave
Hi Dave, both sides can be considered "ramps" as the ball travels between them. Both ramps will be adjusted.
Ankerson
#383
Post by Ankerson »
sal wrote:Hi guys,
thanx.
Sal,
There were a total of 5 overstrikes and about 15 total spinewhacks just to clarify. :)
Right after the video ended it tapped it a few more times just to see, then I went inside and tightened the screws then checked it again. I was going to re-shoot the whole video if it passed explaining the issue and delete the 1st one. I thought there might have been something going on with the knife so I was going to give it a 2nd chance. ;)
Unfortunately it didn't pass though, from what you posted the overstrikes must have damaged the lock.
The Spine Whacks off camera were about the same as the ones on camera or as close as I could make them anyway, nobody is perfect as we all know.
The other damage, I don't really know as I didn't take apart the knife to look.
I can't believe this thread hasn't died yet. :eek:
SaturnNyne
#384
Post by SaturnNyne »
Blerv wrote:Guh. Let the dead stay dead plz ;) . No Frankensteining thx. Lol
More like zombie thread; eet haz come back to eat our brainzz! Like it did before.
sal wrote:As far as the Manix, there will be some adjustments made to the ball travel on the ramp.
That adjustment to the description of the alterations to be made is interesting to me. I speculated before that a part of the apparent performance differences we're seeing might be due to the difference in degree of ball engagement on the tang, since some stop near the edge of the ramp while mine engages quite far down and gives the impression of being seriously burly. I wonder if this is confirmation that their tests found that to be the case.
Ankerson wrote:I can't believe this thread hasn't died yet. :eek:
Srsly!
"Nothing makes a knife maker-designer feel better than to see their efforts used." -Ed
~ My knives list ~
~ Knife photos ~
#385
SaturnNyne wrote: That adjustment to the description of the alterations to be made is interesting to me. I speculated before that a part of the apparent performance differences we're seeing might be due to the difference in degree of ball engagement on the tang, since some stop near the edge of the ramp while mine engages quite far down and gives the impression of being seriously burly. I wonder if this is confirmation that their tests found that to be the case.
Hi SaturnNyne,
It's possible that the ball was too near the end of the tang to take the impact of the strike and transfered energy. There was too much damage to the tang to accurately assess. The ball cut a trough through the tang out to the end of the tang and then coined (deformed) the edge of the rear of the tang (continued the trough).
Our adjusgtments limit the motion of the travel of the ball in both directions. A little less self adjustment, but if someone has the need to overstrike the model, it won't defeat.
JNewell
#386
Post by JNewell »
I'm curious about the degree of variability in the manufacturing process? I raise the question (which doesn't really require an answer) because all of mine (five or six) engage the ramp very deeply.
#387
JNewell wrote:I'm curious about the degree of variability in the manufacturing process? I raise the question (which doesn't really require an answer) because all of mine (five or six) engage the ramp very deeply.
We're talking about a few thousands of an inch.
jylong_away
#388
sal wrote:Hi Dave, both sides can be considered "ramps" as the ball travels between them. Both ramps will be adjusted.
Thanks! That clarifies things for me somewhat.
I understand that there's no way to really 'change' the tang without changing the whole blade, but would it be possible to purchase spare backspacers to replace those on my current M2's? I stocked up on four of them a while ago just before Aus customs started seizing most folding knives as 'flick knives'(it's election month, so all the pollies are cracking down on 'knife crime' by seizing knifes imported by legit collectors.....)
i totally understand that self repair voids warranty - it's really a 'lesser if 2 evils' for me at this point in time, given that I would lose the knives shld I send them to the States for WR. Am absolutely willing to pay for these parts.
Any help would be great...please PM me if this isn't appropriate for the open forum?
Dave
JNewell
#389
Post by JNewell »
I'm not Sal and I'm not Jim Ankerson, but it's far from clear to me that most of us really need the Gen 1.5 Manix 2. You might want to reconsider possibly making a great knife into a dangerous dud by modifying it? Sal says the change is just a couple of thousandths of an inch.
chuck_roxas45
#390
Post by chuck_roxas45 »
What's that they say about opinions and belly buttons?
JNewell
#391
Post by JNewell »
chuck_roxas45 wrote:What's that they say about opinions and belly buttons?
The same thing that they say about "tactical" and now "hard use"... :rolleyes: ;)
chuck_roxas45
#392
JNewell wrote:The same thing that they say about "tactical" and now "hard use"... :rolleyes: ;)
What do they say? ;)
Or is it just you who says it? :p
v8r
#393
Post by v8r »
How much wood could a wood chuck chuck if a wood chuck could chuck wood?
V8R
Opinions are like belly buttons most people have one:p
JNewell
#394
Post by JNewell »
chuck_roxas45 wrote:What do they say? ;)
It's like Shakespeare said...lots of sound and fury...signifying nothing. :eek: :D
Hannibal Lecter
Levity...
#395
Post by Hannibal Lecter »
My Dear Friends,
Sorry - couldn't resist. :p This thread could use a little levity.
Hannibal
"I have followed with enthusiasm the course of your disgrace and public shaming. My own never bothered me except for the inconvenience of being incarcerated, but you may lack perspective."
The General
#396
Post by The General »
No one has directly said it but I detect lots of hints.
I think what everyone is thinking is "how can I tell when I buy a Manix 2 if its the newly improved 'Overstrike' edition"
Of course, there is nothing really wrong with the Manix 2 unless you want to overstike as Sal pointed out. Not something I would be worried about. However, I think it matters to some people so its bothering them.
Perhaps allow for someone to return a Manix 2 to have the improved lock fitted to prevent more moaning on the forum? I know it would cost but it would put threads like this to rest.
My real name is Wayne :D
Blerv
#397
Post by Blerv »
The General wrote:No one has directly said it but I detect lots of hints.
I actually heard all Manix 2, 2.0's will have an etching of Eric Glesser headbutting a rattlesnake on the blade. Well that or melting a diamond with laser eye beams.
The exact design is still in the works.
unit
#398
Post by unit »
Blerv wrote:I actually heard all Manix 2, 2.0's will have an etching of Eric Glesser headbutting a rattlesnake on the blade. Well that or melting a diamond with laser eye beams.
No, I heard it was Chuck Norris and not a rattlesnake....
Thanks,
Ken (my real name)
The General
#399
unit wrote:No, I heard it was Chuck Norris and not a rattlesnake....
I heard that it was a seagull fighting a Great White using an Italian classic stiletto? :D
TrojanDonkey
#400
Post by TrojanDonkey »
If the lock fails due to an overstrike(accident) is it damaged or is it safe to keep using? I heard once a lock is defeated it is no good-I don't believe that all the time,maybe sometimes "depending" on the intended use.This isn't just a Manix 2 question by the way.
