I'm looking for a new driver as well. I had a BM Bluebox, but the bits twist too easily. I have a Husky $5 set, and its bits twist less, but they're a bit small (not perfectly fitted for T-6 or T-8, for example), so they end up stripping screws, too.AliasNeo07 wrote:Is there a particular driver that you guys like? I'm going to order a parts kit and can probably remove the stripped screw with needle nose pliers if im lucky, but I don't want to do this again.
Thanks!
I have this one and have had no issues. The only "screw" I hate to try and work is the single large one on clips like the Tasman Salt.mkd wrote:i use the husky torx set from home depot.it's a bit driver with three or four interchangeable bits that have different sizes on both ends.seems there's a size for every spydie and benchmade i have so far.all the extra bits store in the handle and it was about $8.00 or so.
Users browsing this forum: AlexRus, Bing [Bot], chops688, Deadboxhero, eonbluemantra, Fireman8102, Google [Bot], imjohnsmith, JD Spydo, Liquid Cobra, RamZar, Ric, sabb8pro2, TenGrainBread and 55 guests
