Perfect lube
Caleb
Perfect lube
Post by Caleb »
I'm looking for the perfect lubricant which non retains pocket dirts
i use remington wonder lube but it doesn't dry,sometimes i use ballistol.but i want to buy the most performant lube for my deer spydies.i've heard some words about militec1 and sentry products which one i must choose
thanks a lot!
Alan2112
Post by Alan2112 »
I use Breakfree, on our knives. It sucks for firearms but is great on knives. It dries out before lent and dust can gather in the pivot area, but still leaves a protective coating. If you must use it on firearms, be ready to relube at least every other week! RKBA!
The Stare
Post by The Stare »
I'm pretty much a fan of Sentry Systems TufGlide. I usually use the TufCloth for blades, and the liquid for lubrication of pivots.
IMO, at least so far as lubrication is concerned, don't depend upon one application. I usually see the best results after 4-5 daily applications. I try to make sure the liquid is evaporated before putting away the knife for the next day's dose.
I probably should follow my own example a little better with the TufCloth, and do more applications. On occasion, with a new knife, I've been known to put a small drop of the liquid on either side of the blade and smear it around with my finger until all the blade is covered. Then I try to let that sit until it has evaporated completely, or at least quite a bit from the original wiping.
I think both products are very good. Too many people swear by both of them, for there to be much wrong with either.
The 1/2oz bottle of TufGlide seems expensive. The 8 oz bottle seems very cheap in comparison. But, the 1/2 oz has the thin hollow wire applicator. And, that 1/2 oz lasts a lot longer than one might expect. It is so thin and penetrating, that very small drops go a long way.
Stare
Knife Knut
Post by Knife Knut »
Have not been to Walmart yet, but I heard on rec.guns that Wal Mart now carries BreakFree.
Knife Knut on a shoestring budget.
Zabrewolf
Post by Zabrewolf »
Knife Knut,
The Wally Worlds around here have Breakfree so I would imagine yours would too.
Caleb,
I'm more of a Sentry guy myself. I think the clothes and lube work as well as the hype. The only side bar is I like to use White Lightning for my FRN <img src="spyder.gif" width=15 height=15 align=middle border=0>s. I'm not sure why but it works better than Tuff-Glide (on FRNs, still use Tuff-Glide for SS or G-10).
That's my two bits.
"Ne vyklykaj vowka z leesoo, ..... bo tsej vowk maje <img src="spyder.gif" width=15 height=15 align=middle border=0> ." Don't call the wolf out of the forest, because this one carries a <img src="spyder.gif" width=15 height=15 align=middle border=0> .
Edited by - Zabrewolf on 8/8/2002 7:37:04 PM
kraziekurtis
Post by kraziekurtis »
I have ... Break-Free.
Wouldn't mind checking out some Tuf-Glide and a Tuf-Cloth. Anyone know any stores (not online) that sell them??
sam the man..
Post by sam the man.. »
dude ~ whatabout militec? heard good stuff about it! <img src="wink.gif" width=15 height=15 align=middle border=0>
Sam
have bone implant will travel..
chinook
Post by chinook »
I use Breakfree C-lean L-ube P-rotect to clean any 'gunk' from a very dirty knife. I then use Militec 1 as it bonds with the metal providing lubrication and corrosion protection even when wiped off. You need to apply Militec 1 to a very warm or hot knife for best flow into pivots or tight clearances. I have seen results of corrosion tests where Breakfree by itself was very effective.
I haven't used Ballistol, butt I've heard good things about it. One big plus for it, its food grade and can be used on knives used for food prep.
Disguised as a responsible adult.
glockman99
Post by glockman99 »
I also use Break Free. It smells a little funky, but it works very well, as both a lube and to help protect against rust in the pivot.
Dann Fassnacht Aberdeen, WA glockman99@hotmail.com ICQ: 53675663
KBR
Post by KBR »
I use the Sentry Solutions Tuf-Glide on my Spydies. It works great as a lubricant, as well as, protects the pivots against rust and corrosion. <img src="wink.gif" width=15 height=15 align=middle border=0>
Survive, Adapt, and Overcome...
Edited by - KBR on 8/8/2002 10:22:51 PM
cmassicotte
Post by cmassicotte »
I use Break Free and Tuff Glide. The Tuff Glide seems to be better at not collecting pocket lint, etc
<img src="spyder.gif" width=15 height=15 align=middle border=0> chuck<img src="spyder.gif" width=15 height=15 align=middle border=0>
There is no right way to do a wrong thing
vanman
Post by vanman »
I use balistol.Take care about choosing the
right lube, some are very poisonous. Check
this forum about it. A couple of months ago
some guy and his girlfriend were in hospital
after preparing food with a lubricated knife.
vanman
Post by vanman »
vanman
Post by vanman »
Oops double post.Anyway, I looked it up,the
title is : " Healthy knives, Healthy life "
from 3/11/2002
Knife Knut
This is exactly the sort of reason I revive old threads; take a look at the date on "The Stare"'s post.
J Smith
Post by J Smith »
I was wondering why Caleb was back after the problems he caused.
JEFF .............Sooooo I see the internet is on the computer now.-Homer Simpson
Impyboy
Post by Impyboy »
Recently, I have been looking at 'white lightning' lube coz it's been mentioned a few times before in other forums.
should I go the militec instead? (this is the other one that has been talked about)
-Impyboy
cmassicotte
I have decided to try Miltec-1 -- not just for my knives and firearms, but because my son-in-law tells me it is the best thing for engines since wheels.
As usuall, the best things in life don't come cheap, and this is no exeception.
Does anyone out there know a place that might sell it for a more reasonable price than Miltec does on their web site? They have a special going on right now, but you have to spend a lot of money to save money.
Chuck
Edited by - cmassicotte on 8/10/2002 3:51:11 PM
