Advice Needed on Sharpening ... Please
Spyderknife
I have always sharpened my :spyder: 's on my sharpmaker but of late I have been going free hand on bench stones (DMT and Norton). Been very successful with my FFG blades (Millie, Parra, etc) but for some reason I am just not getting it right with my Delica. Been hesitant to try it on my other hollow ground blades because I don't want to ruin the edge. So at present I have reverted back to my Sharpmaker when sharpening the hollow grounds. Any advice would be appreciated. Thanks!
Never sell my :spyder: knives.
“Whether you think you can or think you can't you're right.” Henry Ford
- razorback1595
- ChapmanPreferred
Spyderknife,
Did you try the Sharpie marker test to see if you had reached the edge while freehand sharpening? If not, because you will have to remove more material (saber grinds get into thicker material a little sooner than full flat grinds) and it may take longer to reach the edge, especially if you are also thinning the angle.
Let us know how it works out!
Doug
Doug
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
Work EDC List
[SIGPIC][/SIGPIC]
Spyderknife
Joe Talmadge
The Sharpie is a great tool to see how well you're making progress. But it is very easy for a slightly errant stroke to grind off the sharpie, when the edge is not actually ready yet. So use the sharpie only as a tool to track your progress. The one way to be certain the edge is ready is if you have raised a burr along the entire length of the opposite edge. If that hasn't happened, that side is not done yet, even if the Sharpie claims otherwise. If that has happened, and if you sharpen the burr off properly, your edge will be incredibly sharp regardless of whether it's flat ground or hollow.
There is no difference between sharpening FFGs and saber grinds. As long as you're getting the edge, you should be getting a sharp knife.
Im not good at sharpening, even with a sharpmaker. How get your blade good can your blade with an edge pro system? - Bladeforums user
Has anyone really been far even as decided to use even go want to do look more like? - Some Online Meme
