Rit dye a Spydie to look camo
RJNC
Post by RJNC »
Any of you Rit dye guys ever tried dieing a white Spyderco knife to look like classic woodland camo? Could it be done?
FIMS
Post by FIMS »
Im assuming if you used the greens and browns and blacks and sort of swirled the dye, it could work, but you would have your work cut out for you.
http://www.spydiewiki.com/
JNewell
Post by JNewell »
You would have to do as many separate dye baths as you wanted colors. That would require masking off areas already dyed and to be dyed every time you dye another color. I'm not sure you could effectively do this at all with the textured FRN.
Lacrosse players use hot glue to mask off areas when they dye their sticks but that's a larger, smooth surface. In theory, I guess you could use blobs of hot glue to mask areas off, but in real life doing an E4 or D4 scale would be a PITA and it's hard to envision it working very well. But, hey, give it a try and show us the pix! :D
FIMS wrote:Im assuming if you used the greens and browns and blacks and sort of swirled the dye, it could work, but you would have your work cut out for you.
Unfortunately, you'd get mud brown or black. You need to ^^^ mask the material if you're going to use dye(s).
CanisMajor
Post by CanisMajor »
JNewell has it right. If you try and you don't like how it turns out, you could just dye the whole thing black.
Canis
Dare. Risk. Dream.
"Your body may be gone, I'm gonna carry you in.
In my head, in my heart, in my soul.
And maybe we'll get lucky and we'll both live again.
Well I don't know. I don't know. I don't know. Don't think so."
- Modest Mouse "Ocean Breathes Salty"
tonydahose
Post by tonydahose »
i think candle wax would be easier than the hot glue gun. :confused:
WTC #1444 Always Remember
My knives
Spydie count: a few:D
noddy
Post by noddy »
I haven't done anything with this dye, but it sounds like it takes so quick, you could maybe paint it on with a brush
RJNC
Post by RJNC »
Yeah I was thinking that too, make the dye really thick and goopy and sort of paint it on.
tkdlaxer
Post by tkdlaxer »
JNewell wrote:You would have to do as many separate dye baths as you wanted colors. That would require masking off areas already dyed and to be dyed every time you dye another color. I'm not sure you could effectively do this at all with the textured FRN.
I was just going to give the lacrosse hot clue didbit.
RJNC
Post by RJNC »
So with the hot glue, I'd have to glue over the parts already dyed, when I put a new color on. So I'd really have to make sure my colors are fully dried on before applying the next color.
BuffaloBill
Post by BuffaloBill »
tonydahose wrote:i think candle wax would be easier than the hot glue gun. :confused:
candle wax would probably work better, but more of a pain to clean out.
[SIGPIC][/SIGPIC]
^Click (needs updating)
FIMS
Post by FIMS »
If it takes so fast to the FRN, could you not airbrush it?
chuck buck
Post by chuck buck »
personally i think its a bad idea. however maybe try an eye dropper for a flecktarn style camo look.
JNewell
Post by JNewell »
FIMS wrote:If it takes so fast to the FRN, could you not airbrush it?
In my experience, it does not take that fast...
JNewell
Post by JNewell »
RJNC wrote:So with the hot glue, I'd have to glue over the parts already dyed, when I put a new color on. So I'd really have to make sure my colors are fully dried on before applying the next color.
You'd have to do both the already-dyed areas and the to-be-dyed later areas. To illustrate, if you want three colors:
1. Mask area 2 and area 3, dye area 1
2. Mask area 1 and area 3, dye area 2
3. Mask area 1 and area 2, dye area 3
JNewell
Post by JNewell »
BuffaloBill wrote:candle wax would probably work better, but more of a pain to clean out.
Bet you're right (on both counts).
RJNC
Post by RJNC »
I'm gonna try the "painting" it on technique on a white frn Ladybug, I'll post pics when I'm done.
Jay_Ev
Post by Jay_Ev »
I'm not sure at what temperature candle wax melts but I would think it would melt right off in the hot water.
cosmo7809
Post by cosmo7809 »
I dont think the "painting" would work... Isnt the whole thing about the rit dye is the heat? That in a way "cooks" the color on...
I like the hot glue idea.
Come Join Us Click Here
RJNC
Post by RJNC »
Well I went for the painting it on technique, I made the Rit dye the consistency of mud and painted it on like camo. I used green, brown and black. Drying now, pics to follow.
noddy
Post by noddy »
bravo! looking forward to seeing this :)
