Show your Mule
enrico
#181
Post by enrico »
"Sir! We are surrounded!" - "Excellent! We can attack in any direction!"
demtek9
Cord Wrapping is HARD!
#182
Post by demtek9 »
Probably not as hard as the wood or micarta handles, but first time doing this took me a few hours.
...oh you know why!
Marion David Poff
Banned
#183
Post by Marion David Poff »
GEAR_JUNKIE wrote:Image
Figured this thread could use a bump. Obviously not finished yet, carbon fiber in the background will soon be on the blade.
JUNK
I am very interested to see how yours turns out.
Marion David Poff
GEAR_JUNKIE
#184
Post by GEAR_JUNKIE »
Thanks. Unfortunately I haven't had time to start the scales yet. Between school, homework, and soccer I haven't had much free time. Hopefully I can start on them tomorrow since there isn't any school.
JUNK
"Submit yourselves, then, to God. Resist the devil, and he will flee from you. Come near to God and he will come near to you. Wash your hands, you sinners, and purify your hearts, you double-minded. Grieve, mourn and wail. Change your laughter to mourning and your joy to gloom. Humble yourselves before the Lord, and he will lift you up."
James 4:7-10
Marion David Poff
Banned
#185
I just wrapped all my mules, just to try some different cord out, and get some images.....
I really like the 2mm cord of the second one down, I unwrapped all but the Strider Wrap'd one, and re-wrapped my ZDP-189 with the 2mm cord.
I am also working on a set of Micarta scales for my M4 Mule, but I am still working the hardware out.
Marion David Poff
jabba359
Post by jabba359 »
After hours and hours of sanding and experimenting with different finishes and application techniques (on leftover scraps), I finally managed to come up with the low-gloss, high contrast finish that I have been looking for. I sanded the stabilized redwood handles to 1500 grit, wiped on a thin layer of shellac with a cloth, let it dry, and then lightly sanded with 1500 grit again to cut down on the gloss. Overall I'm pretty happy with how this turned out (my first Mule scales) and am looking forward to dressing my ZDP Mule.
Finished Mule final.jpg (92.03 KiB) Viewed 7505 times
-Kyle
:bug-red
http://www.spydiewiki.com
jabba359
Post by jabba359 »
And one more picture...
Finished Mule final 2.jpg (95.97 KiB) Viewed 7419 times
-Kyle
:bug-red
DMgangl
#188
Post by DMgangl »
Demtek9,
That is very impressive.
Smile, it can always get worse
Marion David Poff
Banned
#189
jabba359 wrote:After hours and hours of sanding and experimenting with different finishes and application techniques (on leftover scraps), I finally managed to come up with the low-gloss, high contrast finish that I have been looking for. I sanded the stabilized redwood handles to 1500 grit, wiped on a thin layer of shellac with a cloth, let it dry, and then lightly sanded with 1500 grit again to cut down on the gloss. Overall I'm pretty happy with how this turned out (my first Mule scales) and am looking forward to dressing my ZDP Mule.
That looks quite nice.
Marion
DMgangl
#190
Post by DMgangl »
I have 2 S90V Mules right now. Both are wrapped the same way. Here is a crappy pic I took a second ago
DM
GnifeGnut
#191
Post by GnifeGnut »
Nice work jabba359. I like that redwood burl.
jabba359
Post by jabba359 »
Marion David Poff wrote:That looks quite nice.
Marion
GnifeGnut wrote:Nice work jabba359. I like that redwood burl.
Thanks for the complements! And welcome to the forum GnifeGnut! I think you'll enjoy the community that we have here.
-Kyle
:bug-red
Marion David Poff
Banned
#193
DMgangl wrote:I have 2 S90V Mules right now. Both are wrapped the same way. Here is a crappy pic I took a second ago
DM
I like that.
Where does one find instructions on how to do that wrap?
Marion
Marion David Poff
DMgangl
#194
Post by DMgangl »
I wrapped it like a Solomon Bar just like the cord propping it up.
First I did a simple wrap. Similar to the way you did the wrap on the second and third mules you posted. The with the blade facing away from you wrap the handle exactly like a solomon bar for the outer layer. You have to have the blade face away from you so the knot area on the sides goes towards the back of the handle and fills your palm.
I did it for 2 reasons. One I have fat hands and it fills my hand very well. Second this is my camping knife and if for some reason I need some paracord in a hurry I can peel of the outer layer and still have a wrapped handle. I didn't gut any of the paracord.
Hope this helps.
Adam
Marion David Poff
Banned
#195
Thank you.
I remember seeing instructions on how to do that online...
A guy wrapped his hard case Pelican handle like that.
Anyone else seen that how to?
Marion
Marion David Poff
Hector Castro
#196
Post by Hector Castro »
Do you guys make the final shape of your handles before you epoxy them on? If not, how close are you to final shape before you attach them? i am thinking that the closer you can get to final shape before assembly the better. Also the closer you can get to final length on the pins or sleeves the better?
FLYcrash
#197
Post by FLYcrash »
Hi Hector,
Yes, the closer you can get the better, but cutting it close means you have to be very confident of your tolerances. I think some people give themselves a healthy margin of error even if they have very good hands.
Here's a pic of my S90V Mule in a pair of old jeans. I took step-by-step pictures which I may post in a new thread at some point, but that's mostly as an advertisement for Joel Bolden on britishblades and Quickbeam here, whose tutorials taught me what I needed to know. :)
Actually, on this knife, I cut it too close on one edge and had to sand the S90V down almost a millimeter to match the scales in one spot. Sanding S90V is just as hard as it sounds. :o
Picture 129_small.jpg (22.12 KiB) Viewed 7113 times
DMgangl
#198
Post by DMgangl »
I decided to re-wrap my mule to day. Not my best work but it is very fat and fills the hand. The pic also includes the handle of my axe.
DM
Hector Castro
Making multiple scales
#199
I was thinking of using my router and a template bit with a bearing to make scales. I would mount a thick block of wood to one side of the mule to make a nice fitting blank/pattern to work off of. Cut it out on the bandsaw so it is close, then sand it the rest of the way,to match the handle.
Then I could just use this on the router table with the template bit to cut all my material to shape. I purchased 5 of the current mules to play with. I am and advid wood worker, so I think this knife project is right up my alley!
FLYcrash wrote:Hi Hector,
JohnAPA
#200
Post by JohnAPA »
demtek9 wrote:Probably not as hard as the wood or micarta handles, but first time doing this took me a few hours.
That is sweet. Can you describe the materials and if you used a tutorial. I would like to try that style, it looks "Japanese fighting blade."
