type00rev wrote:Frankly......and no offense intended:
Throw away, or sell that overpriced CS Recon Tanto piece of crap and buy yourself a Busse SJTAC (6") or BATAC (5") for your deployment. You can do much, much better than CS. Personally, I would not stake my life on anything Cold Steel, PERIOD. I'm not bashing CS, just speaking from experience (12+ years USMC). Pair up the Busse with the Spyderco Military C36GPSBK (combo edge/blk blade), and your set. I don't know what branch you're in or your MOS......but if you have a man killin' MOS......you should be carrying a Busse into combat. If you need it in a hurry.....call them, Military orders get expedited. The SJTAC & BATAC aren't current production, but Busse may have a few at the shop reserved for Military orders. If not, they are readily available on the BladeForums.com Marketplace.
I chose the CS fixed blade for three reasons.
#1 Its cheap enough to consider disposable. I'm pretty sure a Busse will run me well over $100. The last deployment I went on I used a Cold steel Gunsite large folder. It worked well and the only problem it had was a loosening of the pinned pivot. IMO, Spyderco beats CS hands down for quality. I have become a collector and daily user of Spyderco and I doubt I'll ever own a CS folder again, but the CS didn't have any issues back then.
#2 Its a tanto point that will keep the tip when doing other than cutting knife tasks.
#3 Its SS so I wont have to worry about corrosion as much.
I don't anticipate having to use a knife for self defense. That's what M4s, M9s, and M249s are for. If i can get ahold of a bayonet or a K-Bar for free, I'll use that instead. In my experience fixed blades are ABUSED every time they are needed.
