Stop Bleeding
Vincent
Stop Bleeding
Post by Vincent »
So what do you guys keep in your kits to stop bleeding quickly for major lacerations.
TazKristi
Post by TazKristi »
Quick Clot.
:) Hi Vincent. Nice to see you, hope your school year finished well.
Kristi
vampyrewolf
Post by vampyrewolf »
for light bleeding, I use electrical tape, chucking a hunk of gauze under as needed. Usually a shot of superglue after bleeding has more or less stopped.
For larger wounds I've got a 1/2 roll of duct tape and guaze. Never a question of not having enough pressure. Keep in mind though that duct tape does a number on skin if left on for more than an hour or so.
Coffee before Conciousness
moeman
Post by moeman »
Pressure and then clean it and super-glue it most times.
tonydahose
Post by tonydahose »
out in the boonies, away from ems, i'd use superglue, i haven't looked for it but i am sure you can find the medical grade stuff online somewhere.
edit: i did a very short search on it, go with dermabond or liquidskin
WTC #1444 Always Remember
My knives
Spydie count: a few:D
ozspyder
Post by ozspyder »
Bandaid
Gauze
I need to invesigate Quick Clot and similar products. But I heal very quickly and usually a lot of pressure and bandages will do the trick. Once bleeding stops it'll heal up nicely if you keep it clean and closed together properly. No stitches needed if you look after it.
Cheers
gac
Post by gac »
Apply pressure and go to the emergency room.
ghostdog
stop bleeding.
Post by ghostdog »
celox d in both 15mg and 35mg sizes is available from gustharts uk.expensive but the best and is in military use..comes in a handy size, isreali trauma bandage and plenty direct pressure if the situation demands..
redyps04
Post by redyps04 »
ozspyder wrote:Bandaid
Gauze
Wolverine? What are you doing on the knife forums? You have indestructable metal claws. Lol.
Quick Clot is amazing stuff, just expensive. Still, its something everyone needs to have with them if they plan on camping, rock climbing, hiking, etc.
JaM
Post by JaM »
Superglue here. Non-medical, I dont have any other. Works just fine.
Most of the time IF I cut myself, it's when I'm working on little models (think warhammer-stuff). So most of the time it's on the top of my fingers. And it needs to stop quite quick, otherwise I cant continue ! :)
"in the wild" I'd make sure I have ductape somewhere, a small firstaid kit, and superglue.
And probably a working cellphone. :D
cobrajoe
Post by cobrajoe »
For smaller cuts, I just hold a napkin or towel over the cut until it stops bleeding, I'm a fairly quick clotter. For larger cuts, I carry band-aids in my billfold. For cuts larger than that? I'm not sure, I have only done that once, and there was duct tape nearby (I still have the scar on my leg though).
MEMBER OF THE INTERNATIONAL ORDER OF THE SPYDEREDGE
dialex
Post by dialex »
For minor cuts, I pour salt or cigarette ash. If there's a deeper one, super glue or even thread and needle.
Echo63
Post by Echo63 »
minor cuts get pressure till they stop bleeding then a bandaid or spray on bandaid stuff
slightly more serious stuff gets treated as needed, either steri-strips or a trip to the doctor for stitches
i have only needed stitches twice, both were very short (1/2 inch) very deep cuts, one done with a stanley blade (on my thumb, almost to the bone)
and a leatherman sideclip, (flipping the pliers open, and the blade opened a bit) slid my finger between the half open blade and the handle.
both cuts required 4 stitches
normally i just apply pressure, once its clotted, i just clean it a bit, and use steri-strips
power is nothing without control
BladezAus
Post by BladezAus »
You may want to try Yunnan Baiyao which should be available at any Chinese Pharmacy. It will do a good job at healing wounds with little to no scar. It is poured directly into the wound. It has been used for gunshots and stabbings but this would have to be in the absence of proper medical care. It can even be taken internally to minimize bleeding. It did a great job when the wife had a tooth pulled. It is quite reasonable to purchase. A google search will turn up many sources for online purchase as well as instructions for use.
v8r
Post by v8r »
Last bad cut I had wasn't from a knife it was from a headlight trim ring off of a 68 Oldsmobile 442.I was buffing it on a power buffer( very dangerous no matter what you do),when I heard a wack.It was the trim ring when it hit the wall.I was thinking should I look at my fingers or what? Thats about the time my coworker says hey Jim you are bleeding everywhere.Needless to say it took four stitches in the very end of my finger to sew it back together.my finger never hurt until that doctor stuck that shringe into the end of my finger.I have to say that is the worst pain I have ever been in.I think if I have to have stitches again I think i'm going to skip the numbing agent.Do you guys know if there is any difference?
V8R
Opinions are like belly buttons most people have one:p
coltsfan8116
Post by coltsfan8116 »
dialex wrote:for minor cuts, i pour salt or cigarette ash. If there's a deeper one, super glue or even thread and needle.
+1:d...................
bohica1998
Post by bohica1998 »
[attach]12824[/attach]
Hey! It works!
TimmyBoston
Post by TimmyBoston »
Superglue and bandaids.
TimmyBoston
Can you guys and gals give me some more information on QuikClot? I'm intrigued by this product.
JBE
Post by JBE »
TimmyBoston wrote:Can you guys and gals give me some more information on QuikClot? I'm intrigued by this product.
It's "ok" at best - not quite the "end-all" in bleeding control that it was made out to be. Numerous problems have surfaced with this product and it's use was discontinued by the Military in Iraq even though it's still be marketed to the civilian population here. The Military replaced it the Hem Con bandages for the most part.
Problems included:
1. Exothermic burns caused by a chemical reaction when contacting the skin
2. Failure to stop any type of large flow bleeding, especially arterial bleeds due to the pressure "blowing out" the clot. Also if there is too much blood flow, it will not allow the product to work effectively, if at all.
3. Danger from embolisms being caused by product.
4. The probable need of surgical debridement of the site where the product is applied.
I'm not saying this product doesn't have it's place, but basic hemorrhage control methods are just as, if not more so, effective and with less risk. It's use should be pretty far down on your bleeding control methods and it should be pretty much last-ditch after other methods have failed. However, the manufacturer has made some improvements to the product to make it more effective and with less side-effects. I just can't get over the fact that you're basically pouring volcanic sand into a wound.
Jason
