Could you give me some tips here?
I have a Puma Straight Razor which I shave with regularly.
Initially, the razor performed excellently, just like Gillette Mach 3. I regularly maintain the edge with a Puma strop loaded with Puma stropping paste.
It all started when the razor began feeling dull, giving me cuts in the face. I tried a Black Hard Arkansas, which only made the matter worse. Then I tried a Translucent Arkansas, which did not do any substantial difference to the performance.
I have also the 204 and the additional ultrafine rods, which I have tried.
This weekend I bought a Mach 3 for comparison. The Mach 3 went effortlessly through the beard, but not my razor.
My technique:
Lay the razor flat on the stone, then do one stroke on one side, then one stroke on the other side, using very light
pressure. Repeat this for 10-20 times, never touching the stone with the edge first.
I then finish the process with the strop above.
I watched the video accompanying my 204, and wonder if you can give me some ideas as to what I am doing wrong.
Since I have used the 204 with very good results on my other knives, I turn to you.
Should I use the white rods, as in the video, or should I use the ultrafine rods, which were not available when the 204 and video was produced?
Is my technique correct? Maybe I'm not patient enough...
/Thomas
Thomas J Ekman
Straight Razor Sharpening
Thomas J Ekman
Sword and Shield
