Lube?
- brandonreed2008
Lube?
so i went to the beach last night and went swimming and left my endura on my friends shirt. i didnt tell her (stupid me) and when she pick up her shirt my knife fell in the sand. ive got it all taken apart now and i am wiping everything down. what lube should i use? i was thinking of the "tuf glide" or whatever. also does spyderco make tools for their knives? i had to get an allen wrench and sand it down to size :p
War is mostly waiting.
- WhiteWillie
- brandonreed2008
I have found that by useing a tfelon base machine lube work really good for m.Also I have used powderd grahpite.
Proud to be the adopted father of:
Caly 3 CF
Delica 4 p and ce
Native pe
Tenatious se Bird raven combo
A warm and just thank you for the froum friends who came to me in my time of crisis.It proves that there are still wonderfull human beings in our world.:):)
And still looking for a replacement of my dads Randall 1 combat knife that he left to me. any help would be aapreiceated. I could never afford one, but if any members have any ideas or advice. Please let me know. Thanks
Caly 3 CF
Delica 4 p and ce
Native pe
- BuffaloBill
there is only one way that the torsion bar will go in, the way it is in that picture is almost right but just flip it to the other side, its hard to describe.
as far as a tool to take apart your knives, all you need is a torx set which you can usually pick up at a sears or home depot. i believe its t-9 and t-6 are the most common sizes on most models
Lowes also carries a very good selection of torx kits. And at good prices.
Caly 3 CF
Delica 4 p and ce
Native pe
Caly 3 CF
Delica 4 p and ce
Native pe
- WhiteWillie
Hi Brandon,brandonreed2008 wrote:do you recommend it over tuf glide?
I use Miltec because it was recommended to me by Teddy Jacobsen, a well known and highly regarded pistolsmith here in the Houston area. I'm unfamiliar with Tuff Glide as a lubricant because I've had no reason to change from Miltec. I will say though, that Tuff Glide proved an ineffective rust preventative for me. I used it on a vintage Star PD and surface rust still appeared on the blued finish of the slide.
Mr. Bill
Old guys just know stuff!
:spyder: ATR PE
:spyder: Chinook III
:spyder: Lil' Temperance PE
:spyder: Manix PE
:spyder: Mini-Manix PE
:spyder: Native Black Blade SE
:spyder: Native III PE
:spyder: Para Military (S30V)
:spyder: Spyderfly
:spyder: ATR PE
:spyder: Manix PE
:spyder: Spyderfly
Do NOT reassemble without getting the proper TORX bits. You will likely strip a screw head with your homemade allen wrench. The Husky tool with mutiple bits from Homedepot or Lowes is a good one. Because of variations in screws and tools some people use a T-8 OR a T-9 on the pivot screws. All of the reset on that knife will be T-6.
Don't leave earth without some teeth. I carry a knife to open a can of worms.
Do NOT reassemble without getting the proper TORX bits. You will likely strip a screw head with your homemade allen wrench. The Husky tool with mutiple bits from Homedepot or Lowes is a good one. The pivot screw is not a big concern because it doesn't really get "tight". Go easy with the little screws also, you can always check them after a week or so. Because of variations in screws and tools some people use a T-8 OR a T-9 on the pivot screws. All of the reset on that knife will be T-6.
- jimbo@stn24
I have and use both Tuf-glide, Militec and Blue lube and don't really have a preference. Although I will acknowledge that I've had a tough time staying on top of surface rust on a Remington 870 using Tuf-glide. Have a good handle on it now, but it's been wiped down 10 or 14 times over the last year.
WTC #1455
- SimpleIsGood229
Kobalt 8-in-1 TORX tool at Lowe's
Cheap and very handy, the bits are stored in the end cap. But the cap's a pain to get off.
- brandonreed2008
Thank you! I just picked this up and it's great. Very good for the pricecwt wrote:Kobalt 8-in-1 TORX tool at Lowe's
