I also prefer the old jimping to the new smaller style.spydercofanatic wrote:I agree with ya David. I got 2 paras with the same type jimpin and its almost more grippy than the style thats close together. I see no problem as well :D
Messed up jimping on Para Military
Fred Sanford
Yes the old jimping was like 4 big tank tracks. The Salt had it, the Pacific Salt had it, the Military had it, and the Chinook still has it. The Manix did too.
C'mon guy's there is a huge difference between the jimping in the original pic and JD's pic. While that style of jimping might not always be finished to the same level as we are now used to. The jimping in Mb cooks pic looks like a complete hack job.
P.s here's a pic of the Chinook's jimping, I know it's not quite the same, but as you can see the finish is much better
- Attachments
- jimp02.jpg (35.56 KiB) Viewed 866 times
- jimp01.jpg (38.25 KiB) Viewed 870 times
Fred Sanford
Hey folks,
The first time I came to this thread I only saw the pic that "J Smith" had posted. I didn't know there was a picture from "mbcook76". It must have not loaded. Now that I have seen it I can tell you that it is messy. The very top jimp looks ground down or something. I don't think it's anything I would send a knife back for but it does look sub-par.
RazorSharp86
- Simple Man
The linerlock teeth on my Millie were messed up from the get go, and they would have probably replaced if I had sent it in, but I never did, it still functioned as it should.
The OP's Para Jimping looks uneven and poorly ground, but still functional. It will probably be replaced if sent in, but that is up to you. Personally, since it is on the back and I'd see it more often, it would bug me. I'd probably at least give W&R a call to check into it, either that or talk to the purchasing dealer
Romans 8:31 ....If God is for us, who can be against us? - <><
The Spyderco hole is a rotating mechanical assembly of one part.
".....tractors don't have to look like Ferraris" -Sal
Thanks everybody for taking a look. I'm pretty new to Spyderco knives and I learned a couple of things. From what I read here, this is a type of jimping used on the s30V Paras. Mine does not seem to be well done so I contacted the company I bought it from.
I did order it online so I wasn't able to inspect it, but I also purchased a FG Para which was perfect.
I have emailed the company to see what they say, then I'll make the best of the situation.
Thanks again for all the help!
mbc
mbc
Spyderknife
I would also expect a repair or replacement as I would also not expect that from a high end knife. :cool:mbcook76 wrote:Thanks everybody for taking a look. I'm pretty new to Spyderco knives and I learned a couple of things. From what I read here, this is a type of jimping used on the s30V Paras. Mine does not seem to be well done so I contacted the company I bought it from.
mbc
Never sell my :spyder: knives.
“Whether you think you can or think you can't you're right.” Henry Ford
- Free Radical
