A Story With A Little Serration
MANIXWORLD
Post by MANIXWORLD »
I was using a plastic soap detergent container made of tough hard plastic as a obstacle to do tricks over whilst skateboarding yesterday. Problem was that the wind was quite strong,so weather wasn't playing along,and the plastic container, which was of reasonable size,was simply going to be blown away by the wind.
So next thing that came to mind was,i needed to add weight to the container,but i had to cut the container open because the openinghole was way too small for a nearby rock that i could put in the container to weigh it down.
luckilly my trusty edc Delica4 combo edge ate thru the thick hard plastic of the container with such ease,hence the serration and i could put the rock inside of the container to add the needed weight.
this was a good test to show how tough the D4's are,and that even with a little piece of Spydie serration on a D4combo edge, you can go a long way. thanx for reading...
spydutch
Post by spydutch »
MANIXWORLD wrote:I was using a plastic soap detergent container made of tough hard plastic as a obstacle to do tricks over whilst skateboarding yesterday. Problem was that the wind was quite strong,so weather wasn't playing along,and the plastic container, which was of reasonable size,was simply going to be blown away by the wind.
Imagine how easy it would have been if you used a fully serrated one........ :D
Sorry, couldn't resist :o
Metalbuff
Post by Metalbuff »
spydutch wrote:Imagine how easy it would have been if you used a fully serrated one........ :D
Just imagine how easy it would have been if he just sliced from the "neck" to the "bottom" down the front or back with only one cut. Then just put the rock in that way. Kind of like one of those oval shaped coin holders that go on your keychain with the slit down the center
feeny
Post by feeny »
SE never ceases to amaze me. Im guessing even an SE cricket would have no doubt gobbled that soap box for breakfast :D :D
MANIXWORLD
Amen brother,my full serrated D4 was taking a nap for the day,so second best had to stand in.
MANIXWORLD
Metalbuff wrote:Just imagine how easy it would have been if he just sliced from the "neck" to the "bottom" down the front or back with only one cut. Then just put the rock in that way. Kind of like one of those oval shaped coin holders that go on your keychain with the slit down the center
That indeed would have worked well, too,but why not be a little creative and cut a round hole to see how sharp and well the knife can cut thru hard plastic?not that i wouldn't already know..
wescobts
Post by wescobts »
I just cut some industrial hoses at work with my Native SE and really raised some eyebrows. Most of the guys had heard of Spyderco but have not seen them in action, they were duly impressed. :spyder:
learning it the hard way... :rolleyes:
