Advantages of wide blades?
catamount
Post by catamount »
Many :spyder: s have wide blades (measuring from spine to edge). I realize that one reason for this is to accommodate the hole, but I am wondering what other advantages a wide blade has over a narrow one? Slicing?
One of the reasons I am looking forward to the JD Smith sprint run is that it has a relatively narrow blade for a :spyder: .
Tom
__________________________________
[url]http://spydercovt.com[/URL]
Sequimite wrote:I use knives. I collect experiences.
I'm an admirer of Spyderco's designs. Using them is like immersing yourself in music or studying a painting in a museum. I buy some "fine" art but my preference is for usable art.
Junior avatar courtesy of dialex
kbuzbee
Post by kbuzbee »
Tom, surely some tasks are easier with a wider blade (and the converse, of course) but I think the best "feature" is it makes it easier to thin out the edge (if you like that sort of thing :D ) while keeping the blade stiff and strong. My Lil'Temp (a fairly thick blade) has a wicked thin edge on it because it can. Slices like a Caly.
... and what you said about the hole, of course....
Ken
玉鋼
Dr. Snubnose
Post by Dr. Snubnose »
For SD purposes the wider the blade is, the wider the hole when using the classical comma cut.....A simple test is to stick your knife into some cardboard and twist...measure the size of the hole...Doc :D
Piet.S
Post by Piet.S »
Strenght is also in play.
All your knifelinks, http://www.knifelinksportal.com
benplaut
Post by benplaut »
Agent Starling
Post by Agent Starling »
Knives for cutting individual steaks off the hunk of meat tend to be wider, as do butcher knives...I always assumed that that gave more cutting power.
Agent Starling
"Too many was too many, but way too many was just right."
gull wing
Post by gull wing »
Wide blades just look better in my eyes, they are more sheeple frendly as well.
SCARAMOUCHE! :bug-red-white
OutofGum
Post by OutofGum »
Wider blades also help make straight cuts. Actually, if you think about it, with a pretty wide blade, you can only make straight cuts.
To the pessimist the glass is half empty, to the optimist the glass is half full, to the engineer its twice as big as it needs to be.
philthygeezer
Post by philthygeezer »
benplaut wrote:if the blade is big enough, you can rest your knuckles on it while slicing (food prep)
This is why Chinese chef's knives rock.
Isn't it Japanese Culinary cutlery?
Post by JD Spydo »
philthygeezer wrote:This is why Chinese chef's knives rock.
With all due respect PG I think it's the Japanese that have perfected the wide blade chef's knives :) . One culinary knife seller I've dealt with is "The Knife Merchant" at http://www.knifemerchant.com and almost all of the high quality, wide bladed chef's knives that they sell are Japanese made.
Were you referring to a possible Chinese design maybe that might have been made elsewhere?
Also most, if not all of Spyderco's culinary/kitchen/chef's knives are Japanese in origin. As much as I tend to like USA made blades I have to take my hat off to the Japanese for their excellent culinary cutlery. Not to mention their steel is far superior to that I've seen from mainland China.
SimpleIsGood229
Post by SimpleIsGood229 »
OutofGum wrote:Wider blades also help make straight cuts. Actually, if you think about it, with a pretty wide blade, you can only make straight cuts.
Yep. It acts like a boat's rudder in water.
God Bless Texas!
[RIGHT]Avatar courtesy of Dialex[/RIGHT]
Μολὼν λαβέ
2009 - Birth of the H-1 Spyderhawk! Thank you, Sal!
Generally the wider the blade, the easier it is the maintain control or to cut straight as someone said.
Try cutting through cardboard with the narrow blade from a stockman, then try a Manix or similar. Big difference in how easily they try to turn side to side when you cut.
Of course sometimes being more maneuverable is preferable. My favorite folder is one that I feel strikes a perfect balance between control and maneuverability, the Caly 3.
Slick
Post by Slick »
A narrow blade is like a short wheelbase vehicle. More manuverable and easier to do quick turns. A wider blade is like a long wheelbase highway cruiser. Each has its best uses. I prefer a wide blade for the safety in hard use cutting.
My Jess Horn lightweight is perfect for detail work but is probably my most "dangerous" user. If I were smarter it would not be a danger in use. I should try and carry a narrow bladed and a wide bladed knife to cover more tasks safely. I think I need more Spydies.
Not really all that slick ;)
